restorer-john
Insides:
Cabling is all over the place,no wonder about the mains noise and performance.
That's unfortunate.
Thanks Amir!
With you and other people commenting about Rega's poor wiring practices based on this picture, you probably should ensure it is exactly the same as the unit that @amirm reviewed.
When I look at the picture, I see significant differences. The most obvious being the fuse placement is above the IEC in your picture, versus off to the side and PCB mounted in the Amir's rear panel picture. So we are likely looking at a completely different version to the one tested.
This review from 2015 shows a totally different layout of the DAC-R...
Review: Rega DAC-R
If you mention the brand name “Rega” to audiophiles and music lovers around the world, most will immediately recognise it. Nearly everyone has owned, heard or at least seen a Rega Planar turntable at some point in time.
