- Joined
- Mar 7, 2020
- Messages
- 1,340
- Likes
- 2,140
- Thread Starter
- #361
A few more updates, as ever feedback is welcomed with enthusiasm!
Speaker level switching: after reviewing the properties of a variety of real world amps I've switched the mosfets back to the 200V rated IPT067N20 (https://www.infineon.com/assets/row/public/documents/24/49/infineon-ipt067n20nm6-datasheet-en.pdf). This is a bit more expensive but gives headroom for any practical amp I can find data for from Hypex, Purify, ICEpower, Krell, Boulder, McIntosh, without requiring extensive fail-safe and monitoring circuitry. In theory amps exist that would exceed the 160V safe rating of the mosfets if the amps are wired out of phase, but a quick low-volume qualification check will discover and warn about inverted polarity. The mosfet based switching option is therefore only one that will be on offer to start with, and it has the benefit of silent switching. Also keeps @Armand happy
Single ended board: the single ended board is nearly ready to send for assembly, maybe in a week or so? @KSTR is reviewing it now. Extensive simulations suggest that the single-channel SINAD target is achievable, and that crosstalk is under control too. Hopefully that's borne out in testing.
Other boards: The SPDIF and control boards are also nearly ready.
Case: I'm using a nice-looking but generic split-shell case for the prototype builds, with 3d printed front and rear panels. This makes tweaking easy, but expect something a bit classier after prototyping
Display/UI: I've settled on a 320x240 2 inch LCD. It's not touch-capable, but it's bright and clear. The UI can be operated by an IR remote or over WiFi/BT through a web-app. There are reset buttons and a service USB port on the front panel, and one of the buttons allows to put the DSP MCU into service mode too via the rear USB port.
If everything goes well I should have a prototype ready for testing by the end of September. In the meantime here are some renders:
