- Joined
- Mar 7, 2020
- Messages
- 1,327
- Likes
- 2,113
- Thread Starter
- #221
@Cascode and @KSTR, thanks for the input on the gain stage. It prompted me to recheck a few things.
The feedback impedance near unity gain was indeed too low and not supported. I've increased Rf to 680ohms, at the cost of a small increase in noise. This allows for source impedances down to 75ohms while staying within the datasheet measurement low end of 600ohms. here's a table of the A-weighted noise contribution with a 75ohm source impedance and 2Vrms input:
THD is more complex. At 1kHz, 2V input, 0dB gain and 150ohm or lower source impedance, the datasheet says -134dB. It does rise at higher frequencies and with increasing source impedances, to -123dB at 10kHz and 600ohms, but A weighting brings this back down to about -130dB as the second harmonic at 20kHz is weighted by -7dB relative to the fundamental.
Overall I think I'd like to stick with the OPA1612 solution for its simplicity, low implementation risk, low voltage offset, low noise and broad availability. I may need to rethink the claimed specs to avoid having to surround them with too many qualifications, but measurement is the gold standard.
Rich (BB code):
Gain Output Effective Rg Output noise Noise relative to output 0 dB 2.000 Vrms Open 0.434 µVrms(A) −133.3 dB(A) 1 dB 2.244 Vrms 5.57 kΩ 0.459 µVrms(A) −133.8 dB(A) 2 dB 2.518 Vrms 2.63 kΩ 0.486 µVrms(A) −134.3 dB(A) 3 dB 2.825 Vrms 1.65 kΩ 0.516 µVrms(A) −134.8 dB(A) 4 dB 3.170 Vrms 1.16 kΩ 0.550 µVrms(A) −135.2 dB(A) 5 dB 3.557 Vrms 874 Ω 0.587 µVrms(A) −135.7 dB(A) 6 dB 3.991 Vrms 683 Ω 0.627 µVrms(A) −136.1 dB(A) 7 dB 4.477 Vrms 549 Ω 0.672 µVrms(A) −136.5 dB(A) 8 dB 5.024 Vrms 450 Ω 0.722 µVrms(A) −136.9 dB(A) 9 dB 5.637 Vrms 374 Ω 0.777 µVrms(A) −137.2 dB(A) 10 dB 6.325 Vrms 314 Ω 0.838 µVrms(A) −137.6 dB(A) 11 dB 7.096 Vrms 267 Ω 0.906 µVrms(A) −137.9 dB(A) 12 dB 7.962 Vrms 228 Ω 0.982 µVrms(A) −138.2 dB(A)
The target specifies 0.63 µVrms. However, it might be worthwhile to omit this and focus on only -130 dBA THD+N at 4 Vrms instead, resulting in a target of 1.26 µVrms, see below.
