unmutual
- Joined
- Dec 1, 2024
- Messages
- 115
- Likes
- 115
I have some low end issues remaining in my music listening room , after putting in as much porous absorbtion as I can reasonably fit. Plus I have a very large subwoofer that only handles the sub bass region below 35 Hz. Although I rarely notice that the sub is working, it is helpful to not have my main speakers (floorstanders with good low end extension) handle the lowest frequencies, to avoid exiting the fundamental room mode which is around 36 Hz. I have tried other, higher, crossover frequencies, but with the current placement of the sub, I then get a major cancellation in the 50 Hz region instead. 35 Hz seems to give the best response overall. Multi sub set up is not an option with my current equipment (I would not be able to set different crossovers or do individual time/phase alignment).
As you can see from the waterfall image below, there are ringing in the following regions:
1. below 30 Hz - not so important as there is typically little musical content here in most program material.
2. Around 36 Hz - the fundamental room mode, will be difficult to treat as I have limited amount of space left. And as mentioned above, I have already improved this region through speaker/sub integreation.
3. Around 68 Hz - lower peak than 36 Hz, but more noticeable
So my working strategy will be to target the 68 Hz ringing with a tuned membrane bass trap. I have not found a step by step DIY tutorial for this, but instead have used ChatGPT as a design tool. The recommendation from the algorithm is to make a box of 18 mm MDF panels, with 6 mm MDF as the membrane, and fill the box appr. 50% with fibreglass/rockwool.
I am curious if anyone has tried a similar membrane design, and if so, how effective was it?
Also wonder what you think of my overall strategy of ignoring the deep bass region. I think I would have to use an extra 10-15% of the room space if I were to attempt to improve the sub 40 Hz region, and I'm just not sure it's worth it - but would appreciate all informed opinions on this matter.
By the way, the waterfall is with one EQ filter, but this is outside of the frequency regions mentioned above.
