Rectifier Quest
IEaudiodude
I ave an Olchen EL34-B amplifier, My Psvane 5U4G Rectifier tube started to arc, I have a New Sovtek 5AR4 sitting here I would like to use instead of purchasing another tube. AI says it should be fine, but I don't trust AI all that much, plate voltage will increase a bit .Does anyone here have one of these amps or do you know if it is okay to substitute the Sovtek for the Psvane ?
Is it designed for a 5U4?
Use a 5U4.
Get a good old US 5U4, new or used, you'll be all set. If you're in the US, I'll mail you (a good used) one if you are willing to PM me a mailing address.
The 5AR4 will indeed have less voltage drop -- askin' for trouble.
Not sure any of the current 5AR4 are very good, even when used in a circuit intended for them. Most seem to have lives that are nasty, brutish, and short.
Here's (almost) all you need to know about most vacuum tube HV rectifiers' characteristics. There's a whole (small) "section" on 5U4 "substitutions".
From the above.
I consider the occasional flashes of light from aging Sovtek 5AR4s a form of entertainment included at no extra charge, but those who desire less entertainment might want to consider solid state replacements.
Sure... as long as those replacements are designed with appropriate voltage drop and (ideally) a "soft-start" feature. ;)
I'd still be leery of dropping a 5AR4 (GZ34), or an ss replacement module, into the HV supply for that amplifier unless "we" are (i.e., the end-user is) absolutely sure that the amplifier will be OK with the new operating voltages it'll be exposed to. I doubt (?!) that the P/S in the amp is regulated.
