Jiraya369
- Joined
- Sep 2, 2025
- Messages
- 564
- Likes
- 544
Hello, I've been thinking about getting the Ascilab C6B for some nearfield usage, 0.3-0.8m (Keith at purite has said it sounds fine at 1m, i'd like to know how it sounds at 0.5 m and he's gonna test it, i've asked the manufacturer already let's see what happens, if it's too close i'll get stands and put em beside my table), the main thing is that right behind my table is my bed and i'd like the ability to go back and listen, yeah imaging wont be perfect but better than nothing, around 3 m distance from table/speakers to bed. If he says it wont work maybe I'll go get point source stuff like LS50 Meta. I intend to buy a sub later on, RSL Speedwoofer 10e. Won't need any more with a nearfield setup and in a shared place lol. I have a little BT Speaker, XB100, it's what got me into wanting a speaker and i did some little measuring with a db app on phone and im gonna be okay with 60-65 db sustained and 70 db peaks. add 5-10 db in case the app was inaccurate. I will use a laptop to play back sounds.
Anyways, that was the background. I was initially planning to get headphones but they would cost ~20-30% cheaper only and so i decided to just go for speakers, get a taste of real hi-fi. Was initially saving up for a Hifiman HE1000 V2 Stealth and that is what I want to buy later on. So I will be using a Topping DX5 II as the amp for headphones and DAC for everything.
hen I was thinking of getting a pair of Fosi V3 Mono but would they not be overkill? More power won't hurt but when I would be listening at such quiet volumes idk if it'll be really worth it. I have a recent sale on the Topping PA5 II where I live and I can get it for 130 USD right now. If I get a quick answer I will buy them as that would be a huge saving over the 400 USD V3 Mono, better looking, integrated power supply as well. Less power but more than enough for my needs, used chatgpt to make a table for the power needs and distances and it was way over what i'd need. So I have more than enough headroom should i need it even with a PA5 II.
I've seen some talk about speakers "opening up" with more power/headroom, is that real or is that just the usage of a better quality amplifier? I think the PA5 II is as good as it gets in terms of quality, I don't think I would care for any more.
The main issue I'm facing is integrating the sub with the speakers. DX5 II has no bass management, Fosi's ZA3 does not high pass speakers so it isn't useful at all, my Speedwoofer would only low pass the sub and the speakers would play full range still. Something like the minidsp flex is there but it is just way too expensive for me, i don't want to spend that much on something just for bass management. Then there's the Wiim Amp Pro which I wanted to buy initially but i still would need to buy a separate headphone amp/dac and so i decided to go down this DX5 II with PA5/V3 Mono route but im just stuck here. I'm thinking that I can get the whole setup up and going now and when I buy the subwoofer later on, I can just get a Wiim Pro Plus and use it for bass management. Maybe I can get it on some sale as well!
So what do you think guys? What route should I go down? Most people here are home theatre/non-desktop enthusiasts so it was quite tough going through it all.
The Neumann KH80 is what I was looking at as well but for somewhere around that price I can get a C6B+PA5, seems to me like that's the better buy. It seems to me that the C6B goes lower as well and is exceptionally linear just by itself so that's what enticed me and all measurements are so smooth!!
And finally, how would I even connect all of these together? I don't think cables need to be too expensive, right? Just some cheap XLR cables from DX5 to PA5, and then speaker cables. What kind do i get for the speakers? Sorry for the newb questions, I've never handled any gear like this and i've never done a speaker setup. Oh and i will get a UMIK-1 for room calibration as well.
So, TL;DR,
C6B and (in the future) Speedwoofer 10e setup for desktop nearfield. Planning to use DX5 II as DAC and PA5 II/V3 Mono as amp for speakers, no bass management on dx5 so what can i do? Wiim Pro Plus as a pre amp or something so i can manage bass? What about cables and stuff??
Thanks for reading, would appreciate any help.
So, TL;DR,
