KellenVancouver
- Joined
- Nov 16, 2021
- Messages
- 860
- Likes
- 6,087
I can't speak to other dedicated streamers, but in my other system I use the IOTAVX NP3 which is a sort of "do it all" integrated amp/DAC that includes streaming, and is comparable to the Node 2i in price. The IOTAVX streamer function works just as well as the Node 2i without the hassle of BlueOS (I'm using a free app called Legacy Player via WiiM which works fine), at least for TuneIn and Qobuz, the primary steaming services I use. It is also compatible with Spotify and Tital, amongst others, but I don't use those. In addition to wireless or cabled streaming the NP3 comes with a built-in CD/SACD player and selectable options for PC Audio, Optical, Coaxial, Bluetooth (aptX 24 bit), USB, and even has built-in FM as well as DAB. Uses a Cirrus Logic CS4398 chip which seems to have a fairly decent reputation. If the NP3 had been available at the time I bought the Node 2i then I would have selected it since it also would have saved me from buying the AudioLab 6000 CRT. So I guess that's a bottom line comment: I would buy it again. Hope that helps.What do you think about the other more expensive streamer options vs the Node?
