Recommendations needed - all-in-one amp
jcoldrey
Hey all,
After many years, I am looking to put together a new two channel speaker setup. My goal isn't ultimate audio quality (although as a lifelong audiophile it pains me to say that) but rather a good balance of quality and home-friendliness.
Basically, with the advent of streaming, I figured it would be great to centre the system around an all-in-one integrated amp with streaming, but I'm having trouble finding suitable units to shortlist/audition. Here are my requirements:
- a one box integrated amp capable of powering reasonable quality bookshelf speakers (will be something like Sonus Faber Sonetto 1, ELAC DBR-62, or Revel M105, haven't quite decided)
- Sources will include streaming audio (Tidal lossless, Apple Music lossless, Spotify, Idagio lossless), local files stored on my network (mostly high res audio) and a Rega Planar 3 turntable. So the unit should be able to handle streaming services (or at the very least chromecast/airplay), as well has have a good quality analogue line in (or, even better, a good quality MM phono stage, one less box to have).
- a decent quality headphone out. I have a full headphone setup that I will keep separate (RME ADI-2 DAC FS and Violectric HPA V281), but for this system I'd like to be able to drive a pair of Senn DH600 'phones with reasonable quality.
I guess something like the Naim Unity Atom is functionally appropriate but I'm totally put off by how it measures.
I'm also open to a separate pre-amp and amp setup that can accomplish the same list of things.
Your suggestions will be incredibly useful!
J.
GXAlan
Loooop
Italy
With the same objective I bought the Naim Superuniti about ten years ago and it was my worst experience ever with hi-fi equipment.
I replaced it 15 months ago with a Cambridge Audio Evo 150 and now I'm satisfied because, basically, I can forget it's there - it just works.
I use it with Tidal and with the TV connected via hdmi-arc, coupled with Focal Aria 948 speakers and, rarely, for listening with headphones.
It has an MM phono input, but I don't need it.
Note: according to what I read around, some complain about issues that I have not encountered.
J
jcoldrey
Sounds like it's wise to steer clear of Naim in this space. That Cambridge Audio unit looks the goods though!
radix
You could try something like a NAD C658 which is a streamer + phono input + DIRAC room EQ, then add active speakers (e.g. neumann or genelec). It also has 2x sub out. I've not used it, but I think it has good specs.
You have some options about using the built-in DIRAC or getting the Genelec with GLM correction. It would depend on the subs and such.
Loooop
Italy
In case you missed it, ASR measured the Atom here:
spartoi
For something cheaper, you may want to add the SVS Prime Wireless Pro SoundBase to your list.
