someAudioDude
- Joined
- Jun 19, 2020
- Messages
- 17
- Likes
- 4
Without knowing the internals of the Questyle it's impossible to say exactly what's going on. The Khadas Tone Board has published schematics so I can use it as an example of the sort of thing that can happen - it can be powered by a separate 5V supply so doesn't necessarily need 5V as power from the USB. However it uses the 5V on the USB cable to flip the internal 'switch' that selects the USB input so, even though it isn't needed for power, the USB input won't operate without it. Questyle may be doing something similar.
Proper isolation devices comply with the USB standards, so should Just Work(tm) with any DAC - unless the DAC itself isn't actually compliant. The iDefender and various y-cables etc. break the standards in ways that often work, but sometimes don't. In the past this at least hasn't been damaging...usually...but with USB Power Delivery it can break devices and in extreme cases cause fires.
Hmm thanks for taking the time to elaborate. So, you're saying that using the idefender with an external 5v power supply isn't safe and can cause fire? Wow
Not sure what to do then i already bought the idefender. Shall I throw the questyle into the garbage
