Recommendations for Open-Back Headphones for Bass-Heavy Production
Deemoz
Hello everyone,
I’m in the market for open-back headphones for production and mixing, especially for bass-heavy electronic music (techno, experimental, etc.). My budget is around $400–$500, and I’m interested in hearing your recommendations based on personal experience.
I’ve been considering the Ananda Nano since they’re planar and measure close to a neutral target, but I’m a bit concerned about the distortion measurements—though they seem to have their fans. Another option I’m eyeing is the Sennheiser HD 490 PRO, but I’m worried they might lack sub-bass presence like many other open-back Sennheisers.
For context, I currently own the HD 6XX (love them, but wish they had more bass) and the DT 770 PRO X LE (not a fan overall, use them to focus on low end during mixing).
What do you think about the models I mentioned? Are there better alternatives I should consider in this price range? Thanks in advance for your help!
I 've always assumed boring headphones are best for audio production, like the (closed) Sony MDR-V6?
Hello everyone,
If you really want more bass look at closed back headphones.
Hello everyone,
I'd go for an akg 371. May fall to bits after a year but it's a cheap set with decent Harman oe compliance complete with thunderous sub bass.
Boring = Flat to Harman, but it still must be detailed with quite resolution and separation, Sony MDR-V6 technically is not mixing headphone at all imho.
The Sony MDR-V6 (and its replacement, the MDR-7506) are not what I'd call mixing headphones either. They aren't what I'd call flat:
I'd say the Sennheiser HD 650/Drop 6XX is closer to the mark:
But neither go all that far into the bass all by themselves. The AKG K371 does:
But it lacks finesse in the upper ranges which are more important for mixing.
When eq is applied to the Sennheiser HD 650 there's enough bass to make up the difference. In any case, it's best not to mix using headphones anyway. If you have to, it's better to mix focusing on octaves above the bottom two as most people don't have the playback gear to do that region of sound justice. I've owned all three headphones. The Sony headphones are designed for certain kinds of pro audio applications - they're really good at tracking down the sorts of sounds one doesn't want to hear via PAs like A/C hum and buzz. The Sennheiser headphones are more like good speakers. The AKG headphones are good if you want bass but are a bit deficient in reproducing the upper partials. None of them will "image" like good speakers properly set up.
From personal experience working on electronic music over the years - my HD650 did a pretty decent job for monitoring the subs when EQ'd (I used Sonarworks) - and also paired with Goodhertz Canopener for some crossfeed. So I wouldn't rule out the HD6XX... it's certainly capable.
Nowadays during both the production stage and mixing stage, my low end decisions are made using Slate VSX + the associated plugin, which I've found invaluable. But they're closed back.
HD490 Pro is most logical choice, relatively cheap, reliable, comfy, very flat FR out of the box.
However, they dont have the lowest distortion in bass. They are miles ahead of old Sennheisers like HD600 and other dynamic headphones, but a well sealed electrostatic like Nectar HiveX is far more linear. Electrostatics are expensive, the amps are expensive and they are fragile especially if they are sealed for flat bass extension but the THD is superb.
People often think about distortion as creation of new tones, but that is only the half of the problem. The other big problem of distortion that almost nobody thinks about is the compression, the energy for the distortion harmonics comes from the original sound, the original sound becomes quieter as result, distortion is sonic energy vampire. Distortion compression is basically volume dependent variable EQ, the louder the bass becomes, the more rolled off the bass becomes, not good for music production.
I picked up a pair of HD490 Pro's this weekend for general music listening and some production and so far really enjoying the sound and comfort. A huge step up in sound quality from my old Sony and Beyerdynamic headphones. The bass is tight and clean, could be a bit more thump yes, but still very good. The mids and highs are great without anything shouting at me. I can also listen to them for hours without my ears getting tired, perhaps that's why the bass is not so heavy. I did try the HD600 in the store and they sounded crap to me due to the lack of bottom end.
As others have mentioned. 6XX with EQ will get you most of the way. I'd then reference low end on monitors or IEMs.
A $30 IEM (7Hz Zero2 is a solid option here, I still EQ them for mixing but they're quite listenable without) will get you the sub bass response that open backs can't, without the extremely problematic mid range of most closed back cans (and better comfort personally)
I haven't tried the K371, but based on everything I've heard it still sounds like a lower detail/higher distortion/not amazing build quality can for more money. That being said it's probably the best headphone option for sub response without a terrible mid range for mixing based on the charts. Personally I'm not a fan of the amount of low mid that harman tunings can bring and prefer a slightly more linear bass with a sub bass rise (think "flat' mid range following diffuse field until <80-100Hz or so)
650/6XX+EQ goes a long way, especially referencing to IEMs for low distortion sub. The only other thing I know producers actually use is LCD-X/MM500 with a lot of EQ (Very low distortion, so you can push them up to an elevated sub response) but that's stepping up quite a lot in both weight and price.
I'm in the same boat and didn't want to create a new thread. Beginner at making electronic music and audio gear in general. Currently looking for more filled in bass, just purchased the hd6xx and have a 3 week return window.
What eq settings would be optimal for better deeper base? I'm using Sony 7506 alongside, I know they're brighter buffed, but songs sound better with bass with them, neither eqed. Not using vocals at all in any of the songs I'm producing, just all bass, chords and melodies. Also currently driving the 6xx's with a fiio ka11 dongle.
Posting a couple songs as an idea of the similar bass I'm chasing that just sounds more muffled on the 6xxes vs the 7506.
Emil Rottmayer - Mega
Boards of Canada - Everything you do is a balloon
A tribe called quest - Award tour
For example the EQ presets from Oratory.
measurement of Sennheiser HD6XX
Additionally in the pdf file is a section with comments how to adjust PEQ settings to your personal preference, if it's necessary:
Thanks, I'm new to this just happened to find a video on autoeq that has presets, just need to find a eq to practice with now. I imagine all the entries are just plug in values for adjustments to out of box factory settings, learning as I go.
Welcome to ASR!
I don't know what you know about measurements. Here a link to a video: https://www.youtube.com/watch?v=4xcQX462P90
You need first a software tool, an app or hardware to apply parametric EQ filters that resides on your source. To use AutoEQ is possible as well by choosing your headphone model.
For example Equalizer APO is a free software for pc/laptop. The filters in the oratory file can then converted into a txt-file and imported into EAPO. The format is:
Preamp: -9.3 dB
Filter 1: ON PK Fc 20 Hz Gain 4.0 dB Q 1.1
Filter 2: ON PK Fc 97 Hz Gain -2.5 dB Q 0.7
Filter 3: ON LSC Fc 105 Hz Gain 5.5 dB Q 0.71
Filter 4: ON PK Fc 215 Hz Gain -1.7 dB Q 1.1
Filter 5: ON PK Fc 1300 Hz Gain -1.5 dB Q 1.5
Filter 6: ON HSC Fc 2000 Hz Gain 3.5 dB Q 0.71
Filter 7: ON PK Fc 2700 Hz Gain -1.4 dB Q 3.0
Filter 8: ON PK Fc 3300 Hz Gain -3.7 dB Q 2.7
Filter 9: ON PK Fc 5350 Hz Gain -3.4 dB Q 3.0
Filter 10: ON HSC Fc 11000 Hz Gain -2.5 dB Q 0.71
Don't know which source you use. There are apps for phones available as well. Only on iPhones there are restrictions to apply PEQ filters.
And there is a thread with an overview which EQ tools are available on different platforms.
https://www.audiosciencereview.com/...ows-linux-macos-ios-ipados-and-android.18450/
Don't know what is bass heavy means for you, but open headphones like the HD6xx are usually not made for this. Maybe adjustment to Harman is enough bass for you. For bass heavy it's better to use closed headphone (like AKG K371) or IEMs.
