You might save some CPU cycles that can be used for audio processing, and there are a few audio plugins that use the GPU for processing too, but in your case I don't think it will be a big deal.I read somewhere that you get better performance with a separate video card, rather than the onboard one, which is why I included it. I had a good one in my old machine, because I also used it for video editing. Just wondering if it's worth it. How much of a performance boost does it give if a separate card is handling the video. (The only video that the new machine will be displaying is the UI for Cakewalk and Musescore.) Thanks.
One thing to consider is getting an older GPU that was high end a few years ago. The raw performance increase in GPUs over the past 7-8 years is "only" about 100% and so you can spend a little on a secondhand one, maybe underclock it to lower heat/fan, and have all the video capabilities you need. Alternately sometimes older GPUs get "silent" versions, I had one in my audio PC some years ago.
