For me this isn't what vinyl is about, although I do mainly listen to Tidal rather than vinyl now, but:
If you are used to handling vinyl, and sober, and have decent equipment catastrophic failures in reality do not seem to happen and the fear in the mind sort of disappears after time.
Not all vinyl is pristine anyway. Not even new and especially as the vast bulk of my vinyl was bought secondhand when huge collections were being sold and the quality is quite variable, but it contains many recordings simply not available in digital form. Consider that when you go to a live concert and listen there are noises in the audience and on stage when players move around or drop things etc. etc. yet none of these inherently spoil the musical enjoyment and neither should a bit of noise or pop remove the music you are listening to if the music itself has merit. (Assuming you have your record reasonably clean and are playing with equipment that tends to play through rather than emphasize imperfections)
'Not spoiling it' is not the same as 'it couldn't sound better'.
Anyway, someone making noise in the audience (which for sure can
lessen or
interfere with the experience even it doesn't
spoil it utterly), or players 'moving around' or dropping something onstage (lol, I've never heard anyone comparing those to vinyl scratches, tics, pops) -- these happened to you
once. Whereas an LP is a sound experience you listen to over and over. (If your concert where a mic or guitar got dropped actually managed to get recorded and released, you can bet that noise will be edited out...because most people
don't want to hear it every time)
There's always been a whole lotta caveats involved in vinyl playback, and you've just named some. Sure, as long as you never screw up, and accidents never happen, and you are diligent about cleaning your discs and/or preventing any dirt or dust from being ground into them, pristine vinyl doesn't accumulate noise. And sure, even if it *does*, you can still 'hear through it' ...to a point.
This all tells me that the LP 'experience ' -- the visual, tactile, procedural,quasi-ritualistic,nostaligic aspects of vinyl playback -- is at least as important to some as the quality of the sound. Which I knew already.
For the rest of vinylphiles, the case for digitizing the cleanest copy they can find -- and then declicking it if they want to go that distance -- is pretty straightforward.
Think of them as antiques that perhaps aren't as efficient to use as a soulless bit of tacky MDF of modern design but which have lasted longer and which you *might* enjoy more and each little mark that gets inflicted on them only enhances their character.
If you like 'character' so much, why do you go to lengths to protect your vinyl from gaining more of it?
I think of LPs as obsolete technology that is fascinating to some, like steampunk. And it's funny how every design style eventually becomes an 'antique' that someone craves.
