Recommendations for compact all in one system
saturnine_07
Hi there
Seeking recommendations for a compact/all-in-one system for my child who is having a birthday soon.
I'm based in Australia and looking to spend no more than $500.
I'm looking for something that sounds reasonable, is relatively compact, is simple so a child can operate it, has a built in cd player, DAB, and has modern connectivity like spotify connect.
Something like the new Panasonic SC-PMX112 - I'd consider this more closely but its just been announced and isn't released yet.
Any recommendations?
And for the adults in the room, my main system is Sonus Faber Sonetto VIII, Yamaha r-n1000a, SVS SB4000 and Wiim pro plus. My "desktop" system is Wharfedale Evo 4.2, Wiim amp ultra and an old 12" sub I had laying around (yes I know the Evo's are ridiculous for close in listening but they will be migrating to a bigger room eventually). I may have an addiction and looking to get kiddo into the game early :)
Thanks in advance for any advice
Hi @saturnine_07! Welcome to ASR.
Spotify Connect means that the device needs sufficient display- and user input capability to scan for and display a list of WiFi newtworks, then make the user enter the WiFi password.
So either a built-in LCD and keyboard, or a companion App that transmits the password via Bluetooth.
That's not impossible, but probably difficult to align with your other requirements.
If OTOH you compromise on Bluetooth for Spotify playback, then you'll likely have many more options to choose from.
Looking again that Panasonic does look pretty impressive. Not sure you could do better than that
Those look cool
With right speakers they can sound terrific, I've connected some very expensive speakers to rcd-mX systems and it all have sounded great
It's certainly enough for a child
That Panasonic set up looks amazing. For no money at all you get a lot of functionality.
There is a Wiim Sound Lite Speaker as well. No display or remote, but apparently the same sound quality.
Boom boxes have improved considerably over the years. You can get a used CD player.
The WIIM Sound, and several SONOS speakers have line in. Sonos requires an adapter.
