Recommendations for ~100 ohm nominal impedance, Harman curve compliant headphones.
pollock0424
I'm looking for a Harman Compliant, Approx. 100ohm impedance headphone to use with my Analog sources. I like the 7Hz crinacle IEM but I can't share it with family. Something like in the form factor of the Sony MDR 7506 and with a similar ribbon cable but with performance/characteristics of 7Hz is what I'm after.
Leisure listening will be the usage. Bose QC series comes to my mind.. any thoughts? I'm alright with getting a discontinued/used(fair cond.) item.
Tape machines ranging from studio standard to walkmen and consumer grade record players.
The HD560S is honestly the only good option I can think of:
Everything else has either low impedance (e.g. X2HR, K371), or poor prequency response (e.g. HD620S).
Edit:
Maybe the 620S is good enough?
Open box or second hand audeze Maxwell . It will digitise the analog input so don't think impedance will come into play . Way better FR than the Bose
Is there a specific model ? I found a few with that name..
Edit:
Yeah, definitely! Very close...
Output impedance is something watch out.. power transfer might have a bottleneck at low frequencies.
There's the Xbox /pc one (includes atmos license ) and the playstation one . Playstation version cheaper and other than gaming connection are identical . For your use will be identical
Maybe DT770 80 ohm? Or the 250 ohm one? Tape source could help mitigating the treble edginess :rolleyes:
Some of my tape machines can go past well over 20khz. :)
I will look into your suggestion.
