tackleberry
- Joined
- Dec 30, 2021
- Messages
- 11
- Likes
- 0
Hello everyone,
I am looking to upgrade my home cinema setup to a proper 3.1 or 5.1 system.
Note on Market Availability: As I am based in Switzerland, please note that US-centric brands like Revel or Ascend are often prohibitively expensive here. I have excellent access to European brands (KEF, Dali, Canton, Focal, Arendal, etc.). Klipsch is also available here.
- Budget: Max €2500 for speakers and subwoofer(s).
- Usage: 80% Movies/Series (mostly evening viewing), 20% Music (Metal, Rock, Punk, Electronic).
- Sound Preference: I value detail and clarity. I am not a fan of boomy or exaggerated bass for music; I prefer accuracy over "thump."
- TV: 77” LG C5 OLED
- AVR: Denon X2600 (A Denon X3800H is currently in the mail, as I wanted the better room correction/Audyssey XT32 for the new speakers).
- Current Speakers: Teufel Concept E Magnum Power Edition (PC-style 5.1 system; two satellites are dying).
- Placement: Front speakers and the center will be flanked by walls, firing directly toward the sofa.
- Rear Area: There is significant open space behind the sofa (indoor bike, laundry rack, small home office).
- Construction: Very solid internal walls (I never hear my neighbors). However, the exterior wall is roughly 80% floor-to-ceiling glass.
- Ventilation: Swiss "Minergie" house with ceiling vents. No noise leakage from neighbors so far.
- Note: The flat has Ethernet (ETH) ports in the walls. Could these be utilized for a creative solution for rears or the sub?
- Towers vs. Bookshelfs: I have the space for floorstanding speakers and would prefer them. Are there any technical "vetos" against this?
- Recommendations: Which Front and Center speakers would you recommend within this budget?
- Subwoofers: Do I still need a sub if I get capable floorstanders? If so, one or two? Which brands/models play well with the Denon/Audyssey?
- Neighbor Concerns: I’m less worried about volume and more about low-frequency vibrations. With my small Teufel system, I just turn the sub down. Will floorstanders be harder to "tame" regarding bass leakage? Can I manage this effectively via crossovers/EQ in the Denon?
- Placement: Should towers stay close to the TV rack or as far out in the corners as possible? How much distance from the wall is typically required?
- Toe-in: Straight ahead or angled toward the listening position?
- Creative Cabling: Can the Ethernet ports somehow be used for the sub or active rears?
