- Thread Starter
- #21
Most of the common HPAs, DX9, A90D, L70, A70 Pro, SMSL H400, Singxer SA-1, etc., only run at +/- 15 volts.
You could try to get a used Violectric HPA V280. It also runs at +/- 26 volts, so over 50 volts.
100 ohms at 23 volts and 5.3 watts should still be significantly more than the usual suspects.
With a bit of luck, you can get one of these gems for just under €1,000. That's still much more sensible than sinking it into irreparable devices. Its lifespan with daily use is about 25-30 years, so it's not a risk even if it's used. It can be repaired and overhauled inexpensively by any workshop.
Alternatively, you could also try an HPA V200, which you can get used for €400-500. It also runs at over +/- 30 volts (i.e., over 60 volts total voltage).
I also know several users who run their Susvara, HE1000, etc., with this amplifier and never have to crank it all the way up.
I definitely can't crank my HE6se V2 all the way up on my Violectric HPA V200 (basically half a V280) at 0 pre-gain. At 12 o'clock, I reach my maximum listening volume; from 3 o'clock onward, it becomes unbearably painful, and the volume control goes all the way up to 5 o'clock. The HPA V200 is, of course, only an SE amplifier, but it also has two pre-gain stages, +6 and +12 dB.
The two Susvaras, various HE1000 and HE6 versions, all ran smoothly with the V200.
For the same maximum listening volume with the Topping L70 connected to high gain and balanced, I have to set it to -24 dB. It becomes unbearably painful at -12 dB.
That's a very interesting comment because I was weighing Violetric, there are even some Chinese clones that have their advocates. But apart from the price (I would be very surprised to find it for 1000€ in Europe) I discarded it when I bought the Flux Mentor because there were people who preferred the Mentor to the Violectric and then the Mentor did not convince me. Also the measurements of the Violectric are good, but not as good as the Topping, SMSL. And that it has a lot of power is not my only interest. The clarity, the transparency of the Topping. SMSL, that's what I'm looking for, but with much more power. The construction of the Violectric is much better, of that I'm sure, and if your choice rests on that it's a sure hit. But I don't plan to have the same HPA in 25 years. If the Topping's hold up for ten years I'll be happy with the purchase. And not because I plan to have them ten years, but because I will sell them second hand and the buyer will last several years as well. More and more people are using headphones and this is moving faster than the hifi of speaker equipment. It is not a good idea for me to spend thousands on a device thinking you will retire listening to music on it. Topping have made me a fan of Chinese hifi. I will wait with a little patience to see what can amaze me
