Recommendation for Secondary Monitors to my Neumann KH310s and KH750
MixMaster
Boston
All,
As a Mix and Mastering engineer I have come to rely on my "A" set of speakers; Neumann KH310s with a KH750 Subwoofer. They translate extremely well in my control room which has been acoustically tuned using GIK Acoustics; 17" Soffit Bass Traps, 5" Cloud panels and 5" Absorption everywhere else.
My challenge is finding a great pair of "B" monitors. My budget is ~$4,500 for a pair and I have been looking at the Genelec 8340s, the PMC Result6 and the Dynaudio Core 7 and Core 5 line. My Sweetwater SA is pushing the PMC Result6 pretty heavily but my concern is the specs on power. I believe they have 100 Watts for the woofer and 65 Watts for the Tweeter. I'm concerned there will be issues with a lack of headroom. The Genelec 8340s seem like a strong choice but I worry about the rear port aspect. I do have a 3rd pair of speakers I use, the Genelec 8320s and the GLM Kit does wonders with tuning them. I just don't know if getting the 8340s is the right move either. My desk and speaker stands would bring the Genelec 8340s to within 8" of the front wall but slightly below the GIK panels on that wall. Both of the Dynaudio selections I mentioned above are front ports which is appealing. Both have plenty of power as does the Genelec 8340s.
Also, I use a Coleman Audio M3PH MKIII Monitor Controller. I'm hoping I can get some solid advice here. Thanks in advance for your time.
For 3.4k usd you get a pair of KH150 and still 1.1k left of you budget.
You know THAT was exactly where I started and would have been happy with it. I love the Neumann MA1 software but everything I read AND what my Sweetwater SA said was they would be too close to the sound of my KH310s with the KH750. Everything I read was that I "should" be focusing on anything else but the same manufacturer with the same voicing of all their speakers. What do you think?
If you want your "B" monitors to be highly colored, then the PMC result6 will do that well:
PMC Result6 Professional Studio Monitor Active Speaker predicted in-room frequency response re.png
Though not sure why you'd pay so much for mediocrity, nor how such a speaker would help during mixing/mastering.
If the aim is to test your mixes against different playback systems, then something like this would be vastly superior: https://www.lewitt-audio.com/space-replicator
I am not into mixing and "different voicings" for the job. All I know is that they will sound excellent as well.
Thanks for the reply - I don't necessarily want "highly" colored at all. It's why I'm posting for advice. As I said above, I thought that I liked the Neumann setup I already use (KH310s) and that adding a smaller pair (KH150s) would be a perfect fit until I started researching the best approach to bringing in a "B" set of monitors. As an example the 4" Genelec 8320s I have I consider my 3rd set and I like the mid-forward sound of them. They are using a rear port but because of their size, and because I tuned them to the room with their GLM software there isn't a noticeable problem with bass buildup as a result of the rear porting. Do you have any thoughts on the Dynaudio Core 5 or Core 7?
