- Joined
- Aug 3, 2019
- Messages
- 1,640
- Likes
- 2,526
No it's pasive fixed point 80 Hz high pass on those not Pro SVS and pretty much any other budget one. You lose a lot of SNR by going trough it and while it doesn't matter for a sub, for mains it does. Usually even on higher tire equipment ADC is worrisome part and DSP is far from flexible. With patience and not limited in anything (expect filters that you can apply only once) you can achieve much better results in transition area and transitions for filters such as self low in equal loudness mimicking role and so on. As knew for it is at 105 Hz crossover neads to be a top of it and we'll as it's directional there for 2.2. By now it sounds like simplified Chinese even we didn't touched it in deep or seriously.
Sorry, this reads more like word salad than "simplified Chinese." Thanks for trying to get through to me, though -- I appreciate the effort! Aside from tuning to the room, adding a sub to a stereo speaker pair seems like a slam dunk from here, but no doubt there is something to be said for a more elaborate approach involving a "true multichannel DAC." For the record and FWIW, after discussing the issue with both Kali and SVS support folks, I decided to ignore the sub's high-pass function and simply set the sub's low pass to 60 Hz, which was the alternative suggested by Kali after factoring in the IN-8 woofer's low-end roll-off. As our British friends might say, that seems to "work a treat" here. Peace!
