Recommendation for budget setup: Apple Music to small 4-ohm full-range speakers (~$350 / €300)
Quick update: The Pi 4 2GB arrived today. Full of anticipation, I installed Moode, and it actually runs well. However, booting up takes a full minute, and the device gets warm even while idling. That wasn't part of the deal! piCorePlayer doesn't take quite as long, but it has already crashed twice, or rather, refused to boot up altogether. I'm sending this piece of junk right back and will stick to a non-streaming setup with my Windows PC and an old IPAD Air for now :rolleyes:
I would like to try the WiiM amp but in my country it´s way to expensive.
Moode was never my suggestion. Raspbian with Shareport Sync is rock solid like an appliance!
Oh sorry I thought you were just pairing with a pair of bookshelf speakers. If you also have a sub and want full sub integration then you won’t do much better than the WiiM. Alternatively a used Devon Av receiver that has Audyssey xt32, and use with oca’s free acousticx software.
No problem ;) For now, I’m just using two desktop speakers, but I’m planning to add a sub in the next few months.
I know ;)
But the Pi was so expensive that I wanted to at least try out the streaming apps. I might give it another try with a Zero once they’re available again over here. Otherwise, it would be a bit like using a sledgehammer to crack a nut!
How long does it take to boot, or is your Pi running 24/7?
I know ;)
Pi 3A+ could be available. It is like a bigger Zero 2 W.
I know ;)
24/7 yes.
Boots pretty quick. Box runs cool. I'm happy. I spent like $40 on it.
