I have been using MM cartridges for several years. I upgraded to a Luxman L450 Integrated Amp.The 450 has MC1 and MC2 ability. I would like to venture into the realm of MC cartridges. I rotate 3 Turntables.
1. Denon DP 59L
2. Denon DP 45F
3. Technics SL 1200 vintage 1979
My speakers are Revel F12 floor if that makes any difference.
The maximum mass on the 45f tonearm is 9grams. So to use the MC on all three tables I would need recommendations that meet these specifications.
Budget is $750 to $1500.
Thank you in advance for your consideration.
1. Denon DP 59L
2. Denon DP 45F
