Recommendation for a $3-4k bookshelf speaker (upgrade from Ascilabs C6B)
Save up a bit for March Audio Sointuva AWG, Ascend Acoustics SIERRA-2EX V2 or Ascend Acoustics Sierra-LX, new Revel
To make a long story short, I'm divesting of my horn speakers and tube amp and pivoting towards a class D amp and bookshelf speakers. I have the class D amp already (which I'm happy with) and to dip my toes into the stand-mount/bookshelf speaker world, I opted for the Ascilab C6B (I was lucky to get my hands on a pair a few month ago). These are fantastic speakers for the price, but now I'm looking for a step up.
Budget is $3-4k used or new. A natural choice would be Ascilabs A6B (I would guess they have similar characteristics to the C6B, which I like, just more and better?). But what else is out there that compares favorably, especially when considering used? KEF, Sonus Faber, B&W are recommended a lot, but I'm not familiar with their 'house sound' (if they have one), to make an educated short list. I like neutral, detailed sound, but it could slightly err on the warmer side, with a good 3D sound stage (the C6B stage well in the x direction, but could be better in the y and z axis imho). Would appreciate some suggestions of what to look into. Size should be similar or not much bigger than the C6Bs. Also, I have a small sub, so bass extension is not a big concern, although I wouldn't mind getting rid of the sub either (the A6Bs seem to be quite capable in that regard).
To be frank, I don't see a straight upgrade that isn't a form of higher SPL capabilities and a directivity control that extends lower in the frequency range.
Concerning the second point, you might get some z-axis spatialisation going to a floor stander or an MTM design that reduces the impact of floor and ceiling reflections in the midrange, but that's not a given.
Other than those two points, every "upgrade" is more of a sidegrade that would involve trading one thing for another. Once you have a well controlled directivity like the CB provides, spatialisation on all axes is more a matter of positioning and handling room reflections than a speaker design issue.
Sometimes, narrow dispersion can seem a bit soft or on the darker side; all the details is still there and it can still go loud. It just doesn't always give that "ear filling sound" that you may get used to from other speakers, at low volume. I'm still on the fence regarding the cleaner but less filling sound. Critical listening always gives the win to the narrow speaker because it's currently technically much better than the other speakers I'm comparing. But the others can be more fun or engaging it seems at least for a normal listening session
I tried to convey that in my original post, but probably was not clear enough about it. While the C6B is no slouch with regards to detail, a bit more of it would be welcome. In that regard, the AMT in the Clarity 6.2 could do the trick. But then I'm also a bit weary of a fatiguing top end, so that's a fine line to walk. But most importantly, I'd like to have better sound staging. Again, the C6B are good in that regard, but as described above, I feel, they stage well with regards to width, but could do better in terms of depth and height. Or is that more a function of setup and room interaction?
I have a Wiim Ultra and a small 10" sub and I utilize the room correction and sub integration features of the Wiim. The setup of the sub could certainly be improved, though, as I didn't put a lot of effort into the placement so far (also, there seem to be some resonance effects with my wood flooring).
I think the first step is to send us a picture of your current setup. This could be placement related.
+1 for A6B or Sointuva AWG, end game for me.
Given what you like about the C6B, I’d absolutely keep the Ascilab A6B on the shortlist it feels more like a true refinement/expansion of that same neutral philosophy rather than a different flavor entirely. In your budget, I’d also seriously look at used KEF Reference 1 or Dynaudio Contour/Confidence standmounts; KEF will give you that holographic imaging and precision, while Dynaudio tends to lean slightly warmer and more dimensional without losing detail. I’d probably avoid modern B&W if you’re sensitive to tonal neutrality, as they can sound a bit forward in the upper mids compared to the Ascilab presentation.
If you want your two channel to sound bigger, something like UBach for Windows for around $900 could very well do the trick. I use it on my two channel (along with Dirac ART) with my A6b's and the soundstage is enormous and wrap around. It's also very easy to install if you get your audio from a PC and use something like J River and its VST3 Plugins.
Reactions: Dan
I put together a filter based on your initial criteria... but in my humble opinion, you already have the Holy Grail. Personally, I’d just add an excellent, compact little sub like the SVS 2000 pro or SVS 3000 micro )))) Add also an extra acoustic treatment and you'll see a noticeable improvement. !
This could help you BTW :
Ascilab C6B :
  • Quality of the measurement data is high.
  • Origin of the data is ErinsAudioCorner.
  • Format of the data is generated by a Klippel NFS .
  • Sensitivity:
    • Measured: 85.6 dB (avg. 300Hz-3kHz for 2.83V measured at 1m).
  • -3dB (resp. -6db) point v.s. reference is at 56.4Hz (resp. 45.4Hz).
  • Reference level is normalised to -0.0dB computed over the frequency range [300.0Hz, 5000.0Hz].
  • Frequency deviation is 1.3dB over the same frequency range.
  • Tonality (Preference) Score
    • Tonality (Preference) Score is 5.66 and would be 7.6with a perfect subwoofer.
      • Details: NBD: ON 0.296, LW 0.282, SP 0.257, PIR 0.24; SM: SP0.429, PIR0.595; LFQ 0.755, LFX 41Hz
    • Tonality (Preference) Score is 6.39 with an EQ and would be 7.96 with a perfect subwoofer and the same EQ
If your primary goal is 3d sound stage precision in the vertical plane a coaxial speaker is better. I'd say the kef ls60's perform way above all other speakers I've heard at the price. They are really slender looking coaxial speakers and have a high waf factor.
The Mofi sourcepoint 10 would be a good contender too but probably need a sub.
If your primary requirement is something on the warmer side I'd skip the kef ls60 and look for something with enough bass response. This gives the sound a naturally warmer appearence. The Cadentia 3 would probably be an upgrade but are quite large. You would be willing to accomodate that. Same for Mofi 888.
You just physically need volume to accomodate bigger bass drivers. The best solution imo would be speakers that look slender from the front but are deep and have drivers to the sides. The Ascilab A6b is a same kind of design.
Personally, out of all above, my favourite is the kef ls60. If you really like the C6B, the A6B would likely provide the same but with more bass and perceived 'warmth'.
All the AsciLab designs sound ( more or less ) identical above 1kHz.
The A6B/S6B are both superb.
Forgot to share... but these could be a nice option @$3500 paired with Purifi woofers
Checkout here
Sorry, missed this. Normal basic bookshelfs IMO:
Parts are available, custom boxes will be required, budget is about right. But it's 17-19" wide.
Anything from Philharmonic audio is a tough get these days, they are finally getting the attention they deserve....
Love them, but I'm bearish. They are releasing new products before they even have any of their traditional stuff. And nothing new is being tested. The 6=9 month wait time is too much for me. I fear they are focusing on the wrong things, possibly because they are undercapitalized.
I'm a big fan of Dennis, but there seems to be some scattered ideas going on involving products and product availability...I'd rather see fewer options and more availability of 4 or five models, but it's not my place to judge... they gotta do them...I do think the current tariff policies are creating less options for them as far as availability...
