I just set one of these up in my network, and I can't recommend it enough.
https://pi-hole.net
This is basically a black hole for advertising and telemetry requests on your network. The request goes from your device to your router, which uses the pi-hole as a DNS server. The Pi-Hole decides whether the request should be relayed back to your router or not. The website thinks it served you an ad, or sent telemetry data somewhere, but it just goes into a "DNS Sink"...the Pi-Hole. Ad-heavy news/sports/badaudioreview websites run MUCH faster, and it's fun to watch all the BS getting re-routed into the "DNS Sink" from your apps, smart TVs, etc. It even blocks ad services inside iPhone/iPad apps, since it runs at the router.
https://discourse.pi-hole.net/t/how-does-pi-hole-work/3141
It was super easy to set up - get a Pi (change the password and hostname), install Raspbian, run the install script, give it a static IP from your router, re-set the DNS Server to that static IP and...you're done.
(these are better set-up instructions: https://blog.cryptoaustralia.org.au/instructions-for-setting-up-pi-hole/)
You can check in to the Pi-Hole with your browser and see everything that's been blocked or passed along, which is fun.
Great piece of donation-ware. I donated.
Roughly equivalent to a network-wide version of the free adblocker U-Block Origin does in Chrome (only in the browser, tho), which is, in turn, much better than what adBlocker does, because the serving website doesn't know you are running a blocker.
https://pi-hole.net
