Recommend an external DAC for my phone that doesn't drain the battery. (for Cheap IEMS)
goyetus
TLDR: Recommend an external DAC for my phone that doesn't drain the battery.
On my nightstand, I use a secondary phone as a radio/podcast/YouTube player (and I've been sleeping with the radio on for over 20 years).
Until now, there was no problem, as I've always had a 3.5mm jack. This year, they've decided to do away with the 3.5mm jack on all phones (even low-end ones).
I'm looking for an external DAC with a power supply so I can continue using my 3.5mm IEMs. (With a power supply so it doesn't drain the phone's battery).
I usually fall asleep with my headphones on.
Do you have any inexpensive recommendations?
I have a CX31993 DAC and an IFI go link , but I feel like they drain the phone's battery a lot.
Thanks a lot !!!!!
Thanks a lot !!!!!
If the DAC is well-built and has its own power supply, you can use a USB cable with the positive supply line cut or missing.
This prevents any discharge through the DAC.
thanks a lot for the suggestion !!! Im searching one from europe :)
For a long time I’ve used low-volume audiobook listening to help me fall asleep and to help me fall asleep again if I wake up with insomnia. Using wired headphones was often a pain, with earbuds getting yanked out and the wires getting tangled. Bluetooth earbuds turned out to be the way to go. Using a sleep timer helps reduce battery drain.
apple dongle if you have an iPhone
Thanks a lot !!!!!
How is the condition of the battery in your mobile?
A new battery, if needed, might help.
Is not in very bad condition..... the problem is I use it all night, then I forget to charge it, and next night I cant use with DAC........
Thanks !!!
Android , but it works..... :)
only 0,5 w in Europe (not 1amp like EEUU)
By the way, there are a few DAC dongles on Amazon with an additional charging port. They have a wider compatibility range, and the audio performance is really good, at least with UGREEN. It's perfectly sufficient for IEMs and high-efficiency headphones, and it also works with amplifiers.
UGREEN Magnetic USB C to Jack Adapter and Charging 60W Fast Charge, 2 in 1 Headphone Adapter USB C to Jack with Hi-Res 32 bit/384 kHz for iPhone 16 Pro Max iPad Pro/Mini 6 Galaxy S24 Ultra S23
Thanks a lot !! I was searching for a external dac with power, or double usb c splitter for use with my ifi-go dongle or cyrrus logic dongle (I have a few ones).
I saw a lot of usbc + power with dac like the link you give me, but people says they are really bad quality......
I was thinking also in a Ifi Zen dac , I dont move from the bed, so portable is not the problem......
This is the Splitter I saw yesterday:
Thanks a lot for your help, I will see the comments on the Ugreen you told me :)
Just bought a few days ago a FiiO Snowsky Melody.
Doesnt not get hot like my K11.....and has good sound and is gorgeous.
Thanks a lot !!!!!
Why not keep the phone plugged in and charging while you listen?
I picked up a USB-C Y-cable. USB-C male to phone, 2 USB-C female. 1 for wired headphones, 1 for charging.
So, I can be plugged in and listening simultaneously. (yeah, wired headphones). I’ll use it with a Mojo 2 DAC, too.
https://www.amazon.com/dp/B0DP9PXLMJ?ref=ppx_yo2ov_dt_b_fed_asin_title
