Recommend a cheap dac for repair bench / shop.
tjjrx7
Hello all,
The title sort of says it all. I am looking for a cheapie dac below 100 bucks that I can have on my work bench for testing.
Im really leaning towards the SMSL SU-1. Its cheap, small, and seems to get the job done. But there are so many low cost dacs now that I can't keep up. Is the SU-1 still the best deal going or is there a new kid on the block?
Have you considered bare-bones PCBs (for DIYers) from aliexpress and customize the I/Os anyway a test-bench may require for different needs?
While you are at it @aliexpress, consider what you will/may need; as analog test-gear and variable/clean power supply essentials, all on the cheap DIY-budget.
Some of the current crop of PCs (gamers' grade motherboards) have some very good DACs built-in
Yeah, I actually have. IDK what is going on, but a lot of their offerings that used to be there are gone. Im seeing a ton of sabre boards and then some odd ball r2r stuff. The two or 3 akm boards use the same chip as the SMSL board and after shipping they cost the same amount without the power supply.
I think aliexpress is broken.
PS200 is the new kid, SU-1 still excellent though.
I have a SU-1 just for testing and it works great!
