RCA vs Coax n00b question
Megaken
In the past I've purchased "RCA" cables, "subwoofer" cables, and "digital coax" cables. Now I'm looking at this:
It also mentions video. Now we will absolutely not discuss the quality or merits here, and I am not looking for a personal shopper. I am just trying to understand the following:
Are they all the same? Or are they different but can be combined like shampoo & conditioner into one?
Or any spdif cable can be an RCA cable but not every RCA cable can be a spdif cable? What makes a subwoofer cable different?
Thank you
The S/PDIF standard stipulates a impedance of 75 Ohm. So for digital you better buy a cable with this 75 Ohm impedance.
As it is about impedance, not about DC resistance (almost zero), you can safely use it as an analog interconnect as well.
If you use a normal "analog" interconnect as a S/PDIF cable, in practice short runs will work.
Probably sold a piece instead of a pair.
The Amazon vendor has flooded their title with multiple keywords so their product will turn up whether you search for digital, sub, video, RCA etc. It's common but bad practice.
A genuine domestic video and digital cable will have 75 Ohm characteristic impedance. It will also work fine for normal audio and sub. A domestic 50 Ohm characteristic impedance in theory is wrong for domestic video and digital, but unless the lengths are very long, there should be no issue
Thank you
I've always been of the opinion that an RCA cable and digital coax audio cable funtion the same, the digital coaxial audio cable, intended for use with a sub-woofer, comes with more/extra shielding.
Why does an RCA lead need to be any different from a lead between a DAC and an amplifier that's covering all frequencies, even down to DC?
Exactly. For the best transfer of impulses over S/PDIF, the cable should have 75 ohm characteristic impedance. Same applies to connectors (not fulfilled in audio gear). The longer the cable, the better should it be. Like RG-59. So yes, not every signal RCA cable is a good choice for S/PDIF. If it is 1m long, it will work, though, even if the cable is a junk.
At digital audio frequencies, the connectors are way to short to matter.
In fact, because almost all reasonable coax cables have a Radio Frequency Characteristic Impedance in the 50 to 125 Ohm range. They will all work with shorter digital cables (say shorter than (10 feet/3 meters).
On the other hand, RCA cable connectors are manufactured in many different ways. Some have a 360° shield connections and others may have a long shield pig-tail. Those connectors may be far from the 50 to 125 Ohm range.
Exactly because of this is how the 50-75 Ohm standards came to be in the first place. It's a natural/emergent property of a reasonable coax cable at the usual lengths, so they simply made it a nominal standard.
Meanwhile for cables:
In digital electronics context, we don't have antenna to care about. So the load impedance and cable impedance can be whatever. But higher = less attenuation because higher = less capacitance. But higher also = harder to make. It's scary thinking how much power is being spent on transmitting data simply because we are still using this kind of 2 or 3-digit impedance values even at short distances often.
