Hello, esteemed forum! Newbie here who has put together a budget system that I love thanks to all of your help. So, thanks! I'm a teacher with many other hobbies, so while I'm happy to spend on quality, I can't get too crazy. Fortunately, I DIY in many ways, so I'm happy to hear suggestions in that realm. I'm putting together the final touches of the system (like it will ever be complete!) and had a question about routing via RCA.
First, let me describe the system. The idea is that I would like to have two amplifiers always set up, both powering the same Focal Towers. One is the Yamaha s701 (thanks for the measurements, Amir!), the other a '70s Marantz 2230. Why two? Well, I love the Marantz, especially emotional reasons as a family heirloom. It sounds great, but I don't want to use it as a daily driver and put too many miles on it, pllus... measurements. So, I have the Neohippo VU Meter to switch between amplifiers for speaker connection (and to look good while doing it), but I need to connect all of the inputs. I tried a several RCA switchers of poor quality from Amazon (Solupeak and others) and, unfortunately, I can hear crosstalk between input settings. The need is to split the outputs of a DAC and Phono Preamp to both amplifiers. So, I could get by with two splitters or a 2 in/ 2 out switcher. Ideally, though, 3 in/3 out would enable the ability to connect and try out new equipment.
Question 1: RCA Switcher or Splitter? Some thoughts:
- I tried researching and sometimes there are strong beliefs that there are issues with splitters (signal degradation, humming) and other times strong beliefs there should be no issue at all. But I found nothing definitive. Then, same thing for switchers, but maybe less negative?
- Splitter means fewer steps to music: There is no need to get up/fiddle with settings with splitters, which would be nice.
- Switcher offers room to play/expand: A 3 in 3 out switcher would provide the ability to try new equipment with ease (do 3 way splitters, with one not plugged in cause an issue?)
Question 2: Any specific product recommendations under $200?
- I'm leaning DIY here for high quality Elma switches and then point to point wiring. Recs on specific parts would be great
- But I've also found these. Any thoughts?
..... Imeixi RCA-44 (boasts high quality components, but can't find any info)
..... Vintage Sony AVR Switchers exist, like this one. Anyone have experience?
..... These look great, but hard to justify the price
..... What RCA splitters do you trust?
Thanks in advance for the help.
