Thank you,
@Ropeburn, are you suggesting that the distortion is Contact Pressure not Connector Material. If yes, in this case, how can the Contact Pressure be different, especially as the Connectors look identical with the same Dimensions/Architecture? Yes, in this case, these Connectors are at the Output, although the issue is suggested as Connector Material not Contact Pressure, isn’t it?
- Version1/Not Recommended (note THD+N, FR, SNR/Multitone considered as excellent)
- Version2/Recommended (note THD+N, FR, SNR/Multitone considered as excellent)
- THD+N (High Gain)…. 103/106db (3dB improvement). This can be suggested as significant although many have suggested once better than 100dB (even 95db) that the 3 or 4dB will not be audable, will sound the same, and as such, not significant, haven’t they?
- FR…. Same, Ruler Flat
- SNR (Low Gain)…. 17.5/17.5 bits, same, Superb
- Multitone…. 18/21 bits, both considered excellent. This can be suggested as significant although many have suggested once better than 100dB that the 3 or 4dB will not be audable, will sound the same, and as such, not significant, haven’t they?
- Crosstalk…. Superb/Superb (even better)
- THD+N vs Power…. rise in distortion >10watts/rise in distortion >30watts. Yes, (Clearly) Noticeable, isn’t it, although not Dramatic but is it Audable?
Reasonable Question, for this thread…. is the Connector Material change, Audable, especially as the 103/106db THD+N (consensus) suggests that it will not be Audable?
- For consideration and discussion, for Version 1 where it is Not Recommended…. THD+N/103db, FR/Ruler Flat, SNR (Low Gain) 17.5 bits/Superb (less), Crosstalk/Superb, only THD+N vs Power and Power on/off are (noteable) issue/s. With a THD+N of 103db, the Not Recommended suggests that the indicated issue/s is/are Audable, reasonable….
- Considering the indicated issue was Output Connector Material, the Power on/off noise is a Conundrum/Dilemma, isn’t it? Perhaps, DC Offset/Chargeing Effect and/or PS Noise/Ripple....
- View attachment 533102 View attachment 533103
- Consideration for Vesrion2…. if the Version1 Connector/s were placed after the Version2 Connector/s (if possible), would the Measure/s be the same as/similar to Version1?
Further Question…. if this had occured at the Input, rather than the Output, what would the Measure/s be?…. for consideration and discussion….
