RCA connection question
RTFM. If the documentation says a single RCA-to-RCA is all you need and tells you where to plug that in, that's all you need and a Y-adapter would offer no advantage.
If you have a mono sub out, there's no need or advantage to using a Y to connect both L and R inputs, as far as I'm aware. The only reason to connect both the L and R would be is if you're connecting a device that doesn't have a dedicated sub out and you're taking the L and R full-bandwidth signals and using the sub's crossover to "extract" the bass.
Your "speaker sub out" link is broken, btw.
Link worked for me.
Weird. I get this when I click:
Don't see any obvious errors in the URL.
It seems to be that A100 speakers have only mono sub out right?
Correct. From the manual on that sub, the diagram outlined in red applies directly to your setup:
