Get a Flirc case (i have an unopened one for sale if you’re in Europe) for cooling and aesthetics, but generally the default plastic case is fine for this use.
That's what I use tooI went with the FLIRC case, purely for aesthetic reasons. It turns out it's really good at passive cooling as well.
Thanks!I bought the following four items on Amazon:
1) RPi 4 Board - $50 (this 1GB is sufficient for RoPieee, 2 or 4GB might be good for future projects/expansions)
2) FLIRC Case - $16
3) Cana RPi PS - $10
4) SD Card - $7.50
(I have zero issues connecting Modi 3+ to RPi 4 via a USB. And, running the Modi with the PS it came with.)
2) FLIRC Case - $16
4) SD Card - $7.50
Flash the SD card with the software of choice. I use Moode Audio. USB Pi4 to the same RME DAC.
What was the process for install (Hardware/software) once you received these items? How did you decide what OS to use? I just need the Pi to feed the USB to an RME ADI-2 FS so I can send the music from my MBP to the RME wirelessly. Do you need a wifi dongle to increase the wifi distance/strength? Here is the chain: MacBook Pro -> Audirvana -> Wifi -> RPi4 -> RME ADI-2 FS -> Purifi amp -> F328Be.
