- Joined
- May 31, 2020
- Messages
- 966
- Likes
- 1,737
Just released, 7.998 euro a pair:
“Clarity 66 is the ultimate expression of the Clarity design philosophy. A full-range floor-standing speaker designed for extreme precision, immense power, deep linear bass, and distortion below the threshold of audibility. Capable of reaching breathtaking low frequencies with authority and composure, it does so without sacrificing linearity or control. Every element is mathematically optimized and engineered as part of one coherent acoustic system, achieving unmatched performance and refinement.”
From the website:
THE PINNACLE OF CLARITY
Clarity 66 is the full‑range floor‑standing realization of everything we set out to achieve with the Clarity series: extreme precision, effortless dynamics, and distortion pushed below the threshold of audibility. It’s designed to play deep, clean, and controlled without changing character when the music gets demanding.
Clarity 66 is built as a true 2-way design focused on coherence, timing, and a crystal-clear midrange. The two woofers run in parallel, sharing the load for higher headroom, deeper linear bass and dramatically lower distortion. As the two woofers are identical and always play the exact same frequencies, every last drop of punch and dynamics is maintained. Additionally, with just one crossover region, phase is easier to manage, and the vocal band stays intact. Images snap into place, voices feel immediate, and the soundstage holds steady across a wide listening area.
Usually, designing a floor-standing speaker with this amount of bass extension as a pure 2-way speaker would require too many compromises in the midrange, as the two woofers would struggle to play the deepest bass without modulating or distorting the midrange. However, due to the performance parameters of the PURIFI USHINDI woofers, this problem has been solved.
As such, the design of the Clarity 66 is simple, but executed at the highest level, so you hear the full extent of the recording and none of the system. Effectively, what you end up with is all the advantages from a classic 2-way system, combined with the heft and low-end extension from the best 3-way systems.
From the website:
