Radiant Acoustics Clarity 66 Speaker Review
Rate this speaker:
    Votes: 3 1.1%
    Votes: 28 10.2%
    Votes: 130 47.3%
    Votes: 114 41.5%
Nope, the mess is larger with a 2nd further distanced woofer interfering too at the crossover to the tweeter. The only real advantage of a 2 way configuration is lower distortion at the mid region which in this case is for me an unnecessary compromise unnecessary as the distortion is already so low with the Purify drivers in the mids.
Nope. Here is a $20K competitor:
And its near-field response:
And a budget one:
Are we going to see reviews of the Clarity 4.2 and 6.2 here? They only have a single woofer and cost considerably less, enough for a high quality sub. There's still money wasted on those passive radiators. This is something Ascilab got right, offering a CB version.
The Clarity 6.2 might sport the same AMT and waveguide as the 66, the 4.2 has a smaller AMT with a mini waveguide.
edit: I take that back. The 66 has some vertical lamellae, sort of a linear version of the tangerine waveguide, that the 6.2 does not have,
I don't get how the CEA2034 is titled up but the estimated room response has a correct slope ?
I'm just curious about it.
This is a review, listening tests and detailed measurements of the Radiant Acoustics Clarity 66 Purifi-based speaker. It was sent to me by the company and costs US $9998.
My sample is in black (please don't mind the poor white balance) and looks quite elegant. It also comes in walnut and oak finishes. Despite its modest size this is one heavy speaker! It weighs in at 46 KG or 88 pounds. I felt every bit of it as I moved the darn thing around. :)
Back panel sports the largest port I have seen in a domestic speaker:
It is almost the same size of the woofers! Under load, it pumps out fair amount of air.
The only binding post configuration offered is banana jacks, giving the back a very flat and finished look. I suggest getting locking ones.
The main actor here is not one but two Purifi drivers which are known for their low distortion. Despite its size, speaker is 2-way which I much prefer to 2.5 way we typically see.
Radiant Acoustics Clarity 66 Measurements
Let's start with our anechoic CEA-2034 frequency response measurements:
Response is generally flat with some localized peaks and resonances. They are quite narrow though so should not be very audible. There is a slight tilt up as I have shown with the arrow. Tweeter does have some pronounced resonances and roll off before 20 kHz. I should note that its design created a complex soundfield which was not fully resolved off-axis with the number of points I used to measure. The fins in front of it are the likely culprit.
Early window response shows a dip around crossover frequency (2.4 kHz):
I will show the pinched vertical directivity which is the guilty party:
The sum total looks alright though:
Near-field response shows the issues mentioned regarding tweeter:
Junk coming out of the port is nicely controlled.
Horizontal directivity is not very even:
So some room dependency may exist.
Now we get to the main act: distortion, or I should say lack thereof:
Amazing how the graph at 86 dBSPL hugs the near zero line, even in deep bass!!! It still remains civil at 96 dBSPL. During the sweeps, I only heard some deep bass distortion at 101 dBSPL. Below it sounded very clean.
I don't think I have seen distortion this low at 86 dBSPL.
Our new measurement of low frequency distortion shows off this capability like nobody's business:
We are talking less than 1% distortion in bass frequencies at even 91 dBSPL!
Impedance is typical at minimum of 4 ohm:
Waterfall shows a couple of resonances:
The 300 to 500 Hz was visisible in on axis response.
Step response is clean but has some waviness toward the end:
Radiant Acoustics Clarity 66 Speaker Listening Tests
The first impression was how low the bass response went and importantly, how clean it was. I have never heard a speaker with a couple of small drivers reproduce my sub-bass tracks as if it was a walk in the park! It might be subjective bias but track after track seemed to have more bass than I remember with cleaner reproduction.
As for tilted up highs, my ears are plugged from mowing our dusty field. But I could not detect excessive treble response. I sensed speaker was activating some of my room modes which may have balanced the response out.
With the amplification I was using, I was not able to create audible distortion even at max volume. And this is a very large space with a single speaker.
What do you get when you have the designer of one of the most advanced woofers get involved in a full speaker design? Clarity 66. We are talking about a full range speaker with unheard of distortion levels, doing justice to its name in that region. Yes, it has kind of a cliff that sets in at 101 dBSPL but below that, it likely beats any speaker its size and by wide margin.
Rest of the measurements are good to very good. Slight imperfections are seen here and there which seem to bother the eye more than the ears. For me anyway.
Price is high but we are talking about a speaker produced in Denmark. With luxury fit and finish and robust build. Very robust build.
The Clarity 66 brings true innovation and outside of the box thinking to speaker design. Certainly a feather in the cap of our Danish friends!
I am happy to recommend the Radiant Acoustics Clarity 66.
I see that these use AMT tweeters. I remember hearing those many, many years ago and being very impressed; I didn't know they were still around. Just wondering about the bass-midrange: is it better to have 2 smallish wide-range drivers or larger bass and smaller mid? Is it just about having a nice, narrow cabinet? Anyway, I'd guess that these are hard to beat for £7k.
Physics cannot be undone by comparing different loudspeakers and local disturbances are not the total dispersion/cancellation issues I am talking about.
The vertical radiation of the TAD is clearly less discontinuous:
Even its designer says in his interview about it:
"But of course if you look just at the dispersion pattern you will see that depending on the frequency, when you go vertically off axis at some point you have a destructive interference and one driver kills the other and you get these zeros... all speakers are compromises."
To not compare apples with oranges I also just made a quick simulation which shows this behaviour with a loudspeaker with the same dimensions and also two 6,5" woofers and one waveguided tweeter placed at similar locations and just simple active 4th order Linkwitz-Riley crossovers with just some rough level adjustments and no additional filters to smoothen the absolute linearity of the response as we talk about the directivity:
Here is the loudspeaker
and here its off axis response in a 2-way configuration crossed at 2000 Hz (the lower plots are for the vertical angles)
and in a 2.5-way configuration crossed at 2000 Hz and the lower woofer at 400 Hz:
Also the total directivity index of the 2-way
and the 2.5-way
That's a mistake. Again see my measurements of TAD and JBL and pay attention to response of those woofers as they roll down. There are break ups and resonances mixing with everything else resulting in chewed up response in critical area of 1K to 5 kHz. Using idealized drives in sims gives you highly misleading results. I much rather see a 3-way than any 2.5 way. It is a difference about reality vs theory....
The vertical is... not great. Nicely symmetrical, but wow, quite narrow. Not a speaker for low ceilings! Horizontal off-axis is just OK too, less even than I'd like to see.
AMT tweeter.
Hummmm actually the Taipuu Kero L Active Pro towers use 4x Purifi Audio woofers @6800€ paired (instead of 13600€)
WOOH! Idea picked up from Monitor Audio!
Maybe; there have been through rod speakers for decades
Eg Mordaunt Short 442 . Through rod to rear woofer, attached to steel plate
I also had a cheap-ish JVC speaker that also joined two non identical woofers with a metal rod, in separate enclosure spaces with a port out the opposite face. It was one of those weird Japanese ideas. The ports were pretty trash though and chuffed. It was a solid little box though
Wow !
And I see a price of 8000€ for a pair in Europe...
And £6998 in the UK according to the Hifi News review in the August 2026 edition.
For comparison, my ATC SCM40 Active are £8500 a pair.
I can’t see that review online yet, but the earlier one of the 4.2 model is here:-
Note the exceptional bass extension, and the trade-off with sensitivity below 80dB!
This to Amir for giving us this incisive review as well as to Radiant Acoustic for providing the speaker.
Personally I suspect the speaker's distortion characteristic tends to be under-appreciated. If I'm wrong I'd like to be corrected but it seems to my other speaker shortcoming such as frequency response and some time domain issue can be corrected by FIR filters whereas driver/speaker distortion cannot.
On the contrary, I'd say a narrow vertical on its own is beneficial for low ceilings. What's not so nice is the large crossover dip, that could've been reduced by employing a 2.5 way crossover *and* not using a ribbon(?) tweeter than needs to be crossed so high up (the latter turning this into an entirely different speaker tho).
I didn't see the price at first and thought "this wouldn't be all that bad for 2k per box", but how anybody may go for a 2-way box for 10K is beyond me.
If driver breakups and resonances are an issue that is even more with a 2-way as they happen on both midwoofers.
Also simulations can very well predict the total radiation behaviour, the cancellation lobes can be even calculated by hand, this is not reality vs theory but drawing wrong conclusions on an empirical observation of a too small sample size.
Of course from vertical radiation POV a 3-way is even better although the difference to a 2.5-way is not as high as the 2.5-way to 2-way.
That deal looks great, especially as they're active. If only I needed some speakers right now...;-)
My guess on what we see here: According to spec the lower woofer has a crossover frequency of 90hz. I guess this is where the very shallow lowpass filter starts to have an effect. The deep null at 1khz (~34cm wavelength) is not the lowpass filter, but cancellation between woofer and midwoofer. The rise in amplitude of the woofer above 1khz is not a resonance, but a "return to normal".
@topic: Good to see a floorstanding Purifi design. At the 10k pricepoint it has some stiff competition:
I assume 2-ways have a simpler crossover with a much smaller woofer inductors. Important because they use wire only inductors.
I bet a 2 driver 2-way tower would perform nearly as well? However, all of these Scandinavian speakers are way out of my price range.
