Good morning,
I have some maybe stupid questions as I am a beginner in EQ with headphones.
I've already found good headphones for listening to music through the forum, and I’ve also received good tips for my DT 900 Pro X.
dt770PRO X
Now I have a few questions to better understand EQ curves and how to set them. First, I can’t find any measurements/curves for the new DT 770 Pro X, only for the LE version. The LE response curve stays consistently around 55 dB up to 1 kHz, with a dip around 200–300 Hz, which is where footsteps in games are usually heard and should be boosted.
you can see a curve for the LE here.
Exist a measurement for the new DT 770 Pro X? not the limited edition.
In comparison, the curve of the FiiO FT1 is above 60–70 dB up to around 300 Hz. Does that mean that footsteps are easier to hear?
A friend of mine hears the enemies and their footsteps much earlier than I do with his MMX 330 Pro.
He said he uses sonar eq and boostet everything like, I tried that but the sound changed drastically and I cant play with that eq
the only points he enterd:
123Hz +12db Q 1,5
334Hz +12db Q 1,5
1007Hz +12db Q 0,707
7054Hz +12db Q 0,707
all with peak filter
To understand how EQ works:
The headphone has a curve like in first picture. When I enter only 4 values in APO it changes completly not only the orginal curve it is absolut different?
I thought I change the specific values in original curve but that messed the sound even more.
So where is the starting point for EQ? Flat or the curve?
How do I know the Hz which I have to change?
I can hear better with the DT even though the FT1 should be better in that area because it has more db?
Is there another tool than EQ APO with peace?
Hm sorry I am not nativ english and think my word make no sense? But please ask me so I can understand better.
dt770PRO X
123Hz +12db Q 1,5
334Hz +12db Q 1,5
