Hi everyone. I’m a beginner student majoring in music production, and my teacher for basic audio tech told us that DSD and higher sample rates in PCM (96k, 192k) can bring advantages in sound quality, but didn’t really go into detail. I did some research on my own and mostly found the following points:
1. Most modern ADCs use a Delta-Sigma architecture (which I don’t fully understand). In the first sampling stage, they use a high‑speed, low‑bit‑depth bitstream similar to DSD, then use a feedback loop to push quantization noise up into very high frequencies, and finally apply digital filtering and decimation to get low‑speed, high‑precision data (for example 24‑bit 48 kHz).
2. Digital filters can be either linear‑phase or minimum‑phase, which respectively introduce ringing and phase distortion (how does this actually present itself in terms of what we hear?).
3. DSD seems to use analog filters to handle the very high‑frequency filtering (what are the benefits of doing it this way?).
4. Higher sample rates can move the Nyquist frequency further above the human hearing range, leaving more room for the steep high‑frequency filters and reducing their distortion.
So I’d like to ask:
– Is DSD audio actually better than typical PCM audio?
– Is there any audible difference between the two formats?
– How big are the differences between different digital filters? And what about in the analog filter domain?
– Do the different sample rates like 44.1, 48, 96 kHz have any real‑world significance?
Also, in EQ plugins you can choose different filter modes. When I switch from zero‑latency mode to linear‑phase mode, apart from the added latency I don’t really hear much difference—at least not on piano tracks.
I’ve seen some audio measurements on forums where they test a device’s ultra‑high‑frequency filters, but what exactly are those graphs showing? Does a lower dB value in the filtered high‑frequency range mean the filter is “better”?
So I’d like to ask:
