Good evening Everyone. Well here goes another post am very interested in getting some clarification and maybe some new info on this topic. Here goes. So I have heard for years that gold plated brass is the better metal to use for binding post not nickel plated brass or silver plated brass. So a few years back some new types of binding post has come into the market. Some claim to have pure copper only and real gold plated or silver plated or Rohodium plated. Some claim to do the cyro freeze on binding post and sell them? I have looked into a lot of the binding post claiming they use copper and it’s Red copper. Then the magnetic issue with cheap steel binding post. Can anyone explain this or has there been a test about this subject? There are so many advertisements on this but, very little information on testing on the subject. Is it snake oil or is there some truth to it? Jeff
You can assume that almost all speaker terminals and plugs on the market are magnetic. This is especially true for products that claim to be genuinely gold-plated, silver-plated or rhodium-coated.
This is simply because a nickel layer is applied first, which is always magnetic. You can test this very easily by getting a strong neodymium pot magnet with a diameter of at least 2 cm.
My experience and knowledge on this comes from two areas. Firstly, we have 4mm plugs manufactured and coated in large quantities by two of the largest manufacturers in Europe for our high-energy products. Secondly, I once had the problem of getting plugs and terminals for an audio project that are not magnetic and therefore of course do not have a nickel layer.
I tested over 100 products, well-known manufacturers and no-name, in the price range from €1/$1 to over 100 per piece, and apart from the most expensive WBT plugs and 2 hollow bananas for soldering (1 x raw copper, 1 x silver-plated), all of them were magnetic.
Apart from the three exceptions, all of the products that were advertised with statements such as pure copper, real gold-plated, non-magnetic, real raw-plated, etc., were magnetic.
There were also products, supposedly pure copper, that were copper-plated and had a nickel layer underneath.
You can only be sure that you are getting a non-magnetic product if you test it yourself with a strong neodymium magnet. And I do this with every new delivery, from experience.
A short listening comparison on a very transparent system showed no audible difference between a cheap set of 4 connection terminals and plugs for under 30 €/$ (4 x connection terminals, 4 x plugs, crimp version, magnetic with nickel layer under the gold plating), a set made of pure copper (purity over 99.99%) and a set made of pure brass. The latter two were made as a crimp version for this purpose. The cryogenization was also indistinguishable.
Finally, something about the fairy tale of gold plating.
Gold plating of plugs and connection terminals is absolute nonsense and is purely for aesthetic purposes. Since there is always a magnetic nickel layer between the gold layer and the plug material, the additional gold plating actually increases the overall contact resistance.
The same applies to almost all silver-plated and rhodium-plated products.
One exception I know of are the WBT plugs mentioned, which have a special gold plating that does not require a nickel layer. However, this gold plating is very expensive and costs more than the plugs, even when producing large quantities.
