Talisman
This is how I imagine hell... Forced to eat this thing for eternityMy pizza just arrived. Behold, Hawaiian on a carbon crust. Add some blue cheese dipping sauce.
Good to go. Glorious!
I don't know, a properly built TYPE IV engine does the trick & fits way better:a flat6 of 140HP, that is inefficient. The from the same era (1964) Porche Type 771 engine (2.2L flat6) got 270HP and 230nm torque. It was used in a varity of Porche cars of that time and the decade after it and often used to mod VW Beetles also, as their standard engine was also weak.
You should meet people who keep the 1960s Ultra Vans GM made. These were fairly large for their day motorhomes with a Corvair drivetrain. Yes direct from GM that way. You wonder about the pitch meeting for that project. People love them and are fanatical about keeping those few out there on the road.
Ultra vans are very cool. But they were not designed or made by GM. GM only provided the drivetrain, much like modern motorhomes.You should meet people who keep the 1960s Ultra Vans GM made. These were fairly large for their day motorhomes with a Corvair drivetrain. Yes direct from GM that way. You wonder about the pitch meeting for that project. People love them and are fanatical about keeping those few out there on the road.
Yep, that one will evolve into a never ending & sometimes nasty thread . Then if you add in cut vs button vs hammer forged & gosh forbid barrel harmonics etc.. it's all out the window at that point,In firearms, just ask about cleaning a rifle and what the right procedure and chemicals are. Or better yet, how should you break in a new barrel?
That is a later engine, used mainly by Volkswagen (having the same roots). Porche made a lot of these kind of engines, both for themselves and for Volkswagen, as it was their trademark for decades. Today i would put an M96 engine in such car if it would fit. Those are way more efficient than those older boxer engines. But if you compare both to American V8's, they win both with ease in efficiency and horsepower/fuel consumption.I don't know, a properly built TYPE IV engine does the trick & fits way better:
View attachment 435939View attachment 435941View attachment 435940
This 210HP engine made 196 lb/ft of torque matches the tall gearing in Troutman- Barnes coach built beetle precisely. Watch as Gunnar Jeanette pilots the Revs Beetle in some test laps before handing over the keys to Miles Collier. At Raby’s Aircooled Technology, Jake Raby personally creates each engine himself, to ensure the most complete purchasing experience of a custom, hand built engine possible.
Should you need more, there is this (& it still fit's):
- The 2,913cc engine combination currently holds the Aircooled Technology record for the most “All Motor” street power weighing in at a whopping 284 HP on pump gas!!
- This is a twin plug, EFI equipped engine making huge, reliable power with a power band from 1,500 clear to 6,500 RPM.
Well that whole thing was designed by an air craft engineer so maybe he just wanted an air cooled engine. Considering its size and that it had appliances and a bathroom it is impressive that it only weighted 3100 pounds. I mis-spoke about them being fiberglass they actually are monocoque aluminum. You'll really love this. Originally it used the 80 hp version of that motor. Later they went to 110 hp and finally the 140 hp versions. Those were what were available from Chevrolet so take it up with them. These vans had a two speed Powerglide automatic. My guess is the Porsche engine probably had a torque curve not at all suited for this. Plus most of Porsches other engines back then were less powerful than the one you list. The one you list was only used for racing models I think.a flat6 of 140HP, that is inefficient. The from the same era (1964) Porche Type 771 engine (2.2L flat6) got 270HP and 230nm torque. It was used in a varity of Porche cars of that time and the decade after it and often used to mod VW Beetles also, as their standard engine was also weak.
BTW, I adjust all the parameters you mentioned as specific, typically between the first and second cup, the first cup being akin to the sacrificial 1st pancake. It's not that different from adjusting eq in large venues to accommodate changes in temperature, humidity, audience, and performers.But the most absolutely anal, ridiculous, laughable area is one I don't go to much, and that espresso coffee.
Seriously, for it to be 'proper' espresso it needs to be Xg of means, ground to a particular set texture, the water at a particular temperature, forced through the coffee at a particular pressure, taking a specific amount of time to make a specific amount of espresso. Tolerances of +/- close to zero.
Espresso is a method of brewing coffee, not a particular roast or grind, and though the range of suitable grinds is small, the range of usable roasts is pretty broad, provided you adjust temperature, pressure, and time to accommodate the degree to which the bean's physical structure was degraded by the roast level. That's why it's difficult to do well, but there are rewards for the effort. If you can't appreciate the difference, that fine, but one shouldn't expect others to accept that what come out of Keurig pod or Moka pot is espresso. It's not, any more than what comes out of my espresso machine is French Press or soft serve ice cream. But I will concede that some espresso folk are beyond crazy. I'm tolerant. I wouldn't even condemn you for putting milk in your Earl Grey.Not only are you not allowed to call anything else espresso, you're an idiot if you like, or even don't mind something with a very slightly different taste.
ahhh -- that explains the Econoline accoutrements.Ultra vans are very cool. But they were not designed or made by GM. GM only provided the drivetrain, much like modern motorhomes.
gestalten.com
I'm active in a number of different areas, and one that springs to mind is films on home media - the arguments about the quality of certain transfers on Blu-ray Disc, 4K UHD, etc., etc., can get 'interesting' at times.
I might have posted in that thread, not that the ad-disaster and user hostility that is AK will actually allow me to log in so that I can search the thread.ahhh -- that explains the Econoline accoutrements.![]()
As an aside, but not altogether irrelevant (which is a pretty positive statement, for me!) -- there is a person at (ahem) audiokarma working his way through a restoration of one of the early 1970s GMC Canyonlands RVs. This might be of interest to... well... someone.![]()
https://audiokarma.org/forums/index.php?threads/vintage-1973-gmc-canyon-lands-motorhome.862346/
36 pages of dedication.
A sunset is content, the theme is time.In the photography realm, arguing or discounting a shot someone else took and kept.
Or pictures of sunsets with no theme or context ....
Yes, I have many from a boat at sea. Water & sun & as the sun goes down And the changes in the sunset as the sun goes further down the horizon.A sunset is content, the theme is time.
