Question on HK970 Amplifier
John.D
Friends, I have got this Harman Kardon HK970 amplifier which has power input mentioned as AC 230v ~ 50Hz.
Can I run it on regular AC outlets in the USA?
I tried plugging it and it powered ON fine but I did not connect any speakers to test.
Is it safe to run as it is on USA outlet?
You're lucky it wants 230V and you ran it on 120V... other way around, it would have popped and magic blue smoke would have ensued. ;)
I'd suggest you will need a step‑up transformer to run this properly.
JSmith
JSmith
I did google search before connecting to power and found it’s probably safe and so gave it a try.
How to find which specs would be good enough for Step UP transformer to run this amplifier?
By the way, is this amplifier HK970 any good? Don't know if one of those with tons of distortion as we have seen in a few reviews of old ones.
It's pretty old and I know that it hasn't been used for years. I have ordered step up transformer to see if it does work and how well.
It's an AB amp rated 80 wpc at <0.09% THD 20-20k, so unlikely to have problematic levels of distortion. The SNR spec of 95 dB is a bit meh, but that's typical for H/K in general, so there may be some audible hiss depending on how sensitive your speakers are. (This one uses a WM8816 electronic volume IC on +5V, so not exactly the prerequisites for gobs of dynamic range.) If memory serves H/K gear from this time period can have issues with bad solder joints.
I finally got step up transformer to power this one and it is working perfectly.
No hiss, no heat, no issues really. SQ is excellent as well.
I finally for step up transformer to power this one and it is working perfectly.
Hey neighbor,
I might swing by to have a look at this one at your place over the weekend :)
