Yeah, that should be a new crime for the new century... not as bad...my father was not into music...
How did you swing that? ... as a teenager?I remember when I was able to buy this one new (as a teenager).
Delivering newspapers, vacation job, etc. it took a while. But I was as proud as a two-tailed monkey of course.Yeah, that should be a new crime for the new century... not as bad of lack of mothers' milk but music - as nourishment for the soul - should be birthright!
How did you swing that? ... as a teenager?![]()
I'm not clear as to when this [Sony Szell Beethoven Symphonies] set was remastered. The set with this image on Tidal is Redbook. The single issues with the original covers (marked as 2018) is 24/192. They sound the same, as far as I can tell.
I thought that but it was just me underestimating how much extra power these speakers needed.As the 70s continued progress in solid state electronics meant that amplifier watts were becoming cheaper and easier to obtain - thus encouraging speaker manufacturers to use heavier 'less coloured' cone materials which measured better but removed the life from the music (oops, really shouldn't be saying such heretical things on ASR)
I can see the logic in that but given the nature of increased power vs perceived volume increase did we ever have enough power for those inefficient speakers? No figures or tests to prove it but my brain suggests that the 'stiction' of moving a higher mass cone at lower volume levels might be what robs the bextrene coned stuff of some vitality. There's no wonder that the complexities of speaker design mean that despite apparent progress they're still the audio components with the most sound quality variation.I thought that but it was just me underestimating how much extra power these speakers needed.
The first time I tried the low efficiency speakers (Spendor BC1) I rejected them for exactly that reason but decades later I did a volume matched compare between an efficient, but slightly coloured, speaker and a more neutral less efficient one and with volume levels matched the idea that the more efficient one was more dynamic turned out to be bollox, I just hadn't realised how much power I needed to match the two, and louder always sounds more dynamic.
The Spendor BC1 had very limited power handling though so even if I had realised this back then I am not sure it would have survived or if I had a powerful enough amp available to match volume.
Stiction would be a feature of the suspension system, were there to be any, not the cone material.I can see the logic in that but given the nature of increased power vs perceived volume increase did we ever have enough power for those inefficient speakers? No figures or tests to prove it but my brain suggests that the 'stiction' of moving a higher mass cone at lower volume levels might be what robs the bextrene coned stuff of some vitality. There's no wonder that the complexities of speaker design mean that despite apparent progress they're still the audio components with the most sound quality variation.
A Welsh brass band! - thank you for bringing a smile to my face. Along with a great choice of easy to get to steam railway lines the regular chance to hear a good brass band is one of the few things I miss about living in BritainStiction would be a feature of the suspension system, were there to be any, not the cone material.
I do take your point that it is well possible enough power and power handling may not be available to get high volume from low efficiency speakers.
My favourite speakers are quite efficient, actual efficiency not measured but 5 watts peak on my amp gives similar to concert levels here at home on the piccolo trumpet concerto I am listening to now as the concert (National Welsh youth brass band) I went to on Saturday (they were brilliant!).
I do have a pair of slightly more coloured Tune Audio Anima horns which are 109dB/watt so I can have LOUD if I want![]()
Looking back it seems to me that for every step forward there's always a commensurate step back so that while things might sound a little different actual progress is slow.
For example in the 70s just as high quality stereo FM tuners were becoming commonplace and affordable there was a sudden vast increase (in Britain at least) in the number of radio stations which engendered a sort of 'loudness war' and implementation of nasty automatic compression effects - same thing has happened with television programmes of course, more choice less quality.
I submit that the big leaps occurred when computing resources became practical for use by the audio designers and manufacturers. This led to the electronic circuit simulators and the number crunching for transducer designs, that enabled the "big leaps forward".It’s always been striking to me the degree to which audio and hi-fi discussion seems generally bored by and indifferent toward the epic macro history of innovation in the field and toward the development of electronics in general over two centuries. Instead it’s all small-bore consumer savvy and micro incremental feature obsession and artisanal connoisseurship and technological tribalism that stir the passions and enthusiasm.
I crave so much more sweep and wonder at what we’ve all inherited and enjoy. It’s amazing and almost miraculous.
Every few years I listen to this fascinating and inspirational BBC podcast episode, “In Our Time: The Invention of Radio,” to get a powerful dose of what wrapping one’s head around the significance of innovation can provide. A follow-up on the past century of progress in audio fidelity and distribution would be incredible.
BBC Radio 4 - In Our Time, The Invention of Radio
Melvyn Bragg and his guests discuss the invention of radio.www.bbc.co.uk
As a millennial, I feel like there hasn't really been any massive improvements in fidelity in my lifetime.
Were there any moments that stood out to you? Anything that blew you away the first time you heard it?
I love the CD format and never played vinyl again since they rolled it out. Dont stream either. I want the physical CD in my possession. I listen to Classical music so thats the best format. For metal yeah use your vinyl. The music itself is distorted anywayNever really liked cd... Unlike vinyl, I scratched them easily and broke many a case. For some reason vinyl demanded respect so stated with it.
However mp3, napster, mass consumption, suddenly being able to find that rare recording you could never afford in mp3 or that version of a mix etc... Explosive and in a way devalued music... I guess supply and demand.
Here I am still holding vinyl I bought as a child and still do today. Now we have commercial streaming which I also use.
However haven't purchased a c90 since circa late 80s and cds I still avoid. If only on cd why buy when same or better digital format on streaming... Vinyl for me now is a collection. I won't change. Fir now
