tmtomh
- Joined
- Aug 14, 2018
- Messages
- 3,620
- Likes
- 10,880
Okay, dumb question time:
In another thread I've mentioned I want to replace my aging computer music server with a Wiim Ultra. I've just received the Wiim and done initial setup - and now I have a question about Genelec and GLM with this new setup.
Old Setup:
New Setup:
Thanks!
Old Setup:
- 8351b stereo pair-->GLM Network Adapter-->old computer. Computer also sends music to the monitors (via USB-->coax-->AES EBU.)
- I keep the GLM Adapter permanently connected mainly so I can use the little Genelec wireless remote for Power On/Off and volume control from the comfort of my midfield listening seat.
- I do not control the monitors with the GLM software on the computer in day-to-day listening. Unless I want to run a new room calibration or change a setting, I never fire up the GLM software.
- For this reason, the monitors' "STORED" DIP switches are set to ON - so when I turn them on they can use the GLM settings I've saved to their internal memory (since the settings aren't available from the software, because the software is not running on the computer).
New Setup:
- Wiim up and running and has replaced my old computer for purposes of sending digital music to the monitors.
- Now I would like to remove the computer from my setup entirely - in other words I would like to disconnect it not only from the monitors as I already have, but also from the GLM Network Adapter. And to be clear, I want to keep the Network Adapter connected to the monitors because otherwise I lose the ability to use the Genelec wireless remote.
- Google search/AI says this is simple: just disconnect the computer and instead of powering the GLM Adapter from the computer's USB port, power it from AC mains by using a typical 5V USB wall plug and cable.
- Since I don't normally run the GLM software anyway, and since the monitors are already set to use their internally stored settings, everything should be fine this way - I should still be able to use the Genelec wireless remote, and the monitors should still apply their normal filters and other settings.
- But while this sounds logical and Google says it will work, I haven't actually been able to find anything on Genelec's own support pages that address this kind of setup. All their support pages seem to assume you either have a computer with GLM software always running, or else that you are using the monitors in standalone mode without the GLM Network Adapter and therefore without any of the available Genelec wireless (or wired) remote control devices.
Thanks!
