observerstation
- Joined
- Sep 27, 2024
- Messages
- 7
- Likes
- 5
Hi,
I am fairly new to having a pure digital set up and I am curious as whether the quality of USB or Optical cables is relevant to the sound quality. I am looking for a general consensus on whether it's worth to spend money in this area. Here is my set up;
- Running Audirvana on a MacBook M1 Air playing local Flac files from my own music library, and also using Spotify app on a Smart TV via Optical cable
- Laptop connected via USB to a SMSL SU-1 Dac (This acts as both a power supply to the Dac and to transfer the music files)
- Dac to Fosi ZA3 Power Amp
I am currently using a non-audio specific USB cable.
I have heard that Audioquest cables will improve the sound (or is this just snake oil?)
What qualities should you look for in a USB cable? Is it transfer speeds only or do the Audioquest cables have something else that's important?
Thanks!
Thanks!
