Rod
- Joined
- Mar 24, 2018
- Messages
- 761
- Likes
- 356
I could use some help?
I have a Seaton Submersive sub that is dual 15 inch woofer and a 1000 watt ice amp that I use for movies most of the time. But it sits in a corner and is directional at least in this room. I also have a store credit at a retailer that I have to use there for a return. So after looking through all the stuff I dont need, I started to look at there subs that I dont need either.
Here is something that I am at a loss for answers. If I buy the Monolith by Monoprice 10" THX Select Certified 500 Watt Powered Subwoofer(https://www.monoprice.com/product?c_id=109&cp_id=10906&cs_id=1090602&p_id=24456&seq=1&format=2) and sit the sub in the opposite front corner to the Seaton sub, can they be used in tandem or would the difference be to much? I would just be trying to fill in the opposite corner with base freq. in a 20x20 room. Would the Seaton just overpower the other , or could the second sub just help "fill the corner" in the frequencys and loudness levels it can do and sound ok without turning the Seaton down to try to match? I dont know what the suggestions are for dissimilar subs.
