I've had several headphone amps over the years (Fiio, JDS labs, Schiit, Drop THX 789 etc.). I also own an old Audiolab 8000A integrated amp (the early 90's UK version with the bass & treble knobs), which is mostly just stored away.
The old Audiolab has a feature that I think is being faded out in recent years from speaker amps- a headphone jack. Every now and then, I take out the old Audiolab to be used just as a headphone amp. And I gotta say, it sounds every bit as good as any dedicated headphone amp I own with one major advantage- it has orders of magnitude more power.
With my Drop HD6XX, with certain recordings, I have to use the THX 789 at maximum volume to get an enjoyable listening experience, with some headroom still lacking (this is fixed if using XLR signal path which manages to give the few more extra DB needed). However, with the integrated amp, there seems to be an endless abundance of power, far more than the headphones (or my ears) can handle. Actually, the only reason I don't just use the Audiolab is that it takes way too much space on my table.
However, I just wondered- Is there a fundamental difference between a speakers amp with a headphone jack and a dedicated headphone amp? Are the dedicated headphone amps just a form factor sacrificing power for taking less space? Or are they designed in a way specifically benefiting headphones in some way?
