The one that puts out 2db more?
Could be either one, we can't see it when it is playing alone.
https://7-zip.org/ for examplewith what? winzip demands paid subscription.
Green is running both with right sub inverted. Purple is running both with left sub inverted. Orange is both with none inverted.
yes sir. I also think if it was polarity, they wouldnt look so alike when measured individually.That is ..very strange.Are you inverting in MiniDSP?
yes sir.
They are. If they dont, the line would be flat. The measurement is higher.have you felt the drivers to check that both are actually playing?
One look at the .mdat and the answer is pretty clear. @Flaesh was right all along. I was so confident that it would be a phase issue that it was the very first thing I looked at.
Blue: L sub sans miniDSP
Purple: R sub sans miniDSP
The subs are 160 degrees out-of-phase with each other. The result:
Broad area of phase cancellation when the two subs play together. The highlighted curve (in dark purple with yellow glow) is the two subs playing together, and the lighter coloured curves are individual subs.
Now I will show you some proof that Trace Arithmetic A+B predicts the measured result. In red, we have L+R subs added together with REW. In purple, we have your measured result of both subs playing together. You can see the two curves look almost the same.
Now look what happens if we invert the polarity of one sub, and add it to the other sub. The result is shown in green. I am comparing it to the previous graph, with both subs un-inverted (red). Ta-daaah!! Looks much better, doesn't it?
BTW I am pretty certain that the graph you posted here is a complete BS result. It is impossible for you to invert the polarity of one sub and have the sum of both subs measure exactly the same as having both subs un-inverted.
It also appears that you are measuring in a very noisy environment. If you want to see for yourself, go to the waterfall window and extend the time window to 1000ms. The noise is the flat area of the waterfall. Click through each measurement and you can see the noise floor changing between all the measurements.
One setting, okay, but both invert options not working in MINIDSP? When I tried a few days ago too? I checked and double checked the connections, the wiring. The fiddling with invertion should show some kind of response. It did not at all. The UMIK1 SPL gauge in REW, went bananas at times. I saw 20db when both subs went at the same setting that previously showed 74db.Very simply, you have made an error when you inverted the polarity of your subwoofer. You failed to invert it, when you thought that you did. Like I said, the graph you posted earlier is impossible. I would be looking into that if I were you. Once you fix it, the result will look like my last graph.
Even if you might have a point, I am possitive windows is messing up or has messed up REW. Ill need to make a clean install for the microphone files, the soundcard settings etc and then run again but just changing and turning off the microphone enhancements - some kind of voice filter, made a big difference.
That said, i hope you are right.
Ill make new measurements sans minidsp to be sure. Then ill add minidsp again and try to invert. Hold on, i think the inuke6000dsp amplifier for the subs, also has a polarity switch option.
@sigbergaudio they are both DIY. One i made myself (the 2, R)). The other (the 1, L)was assembled. I removed the screws but couldnt get the driver out. The one i made myself i double checked. If Keith is right then perhaps i do need to open the assembled one to fix it. I actually really hope so.
Thanks for the effort guys. Really appreciated.
Ah, but me being in a wheelchair that isnt easy to do.If both are "wrong" it will also work, so you could still test switching on the one you can open. I would perhaps also test to put them both in the same position, so next to each other or stacked on top of each other and see what happens.
Never realized it was a passive sub. Then you didn't need to open it up of course, just reverse the speaker wires.![]()
