the_lumberjack
- Joined
- Nov 11, 2024
- Messages
- 7
- Likes
- 7
I just watched Amir's video called "GR Research B24 AC Cable Review: Does it Make an Audible Difference?" and something occurred to me.
I get that running the digital file comparison test is proof that there is no audible difference between two cables, because the difference between the two files is just noise below the audible threshold. But audiophiles claim that there is an audible difference that can be explained by having a lower noise floor directly translating into better instrument separation and bigger soundstage. I have two questions:
1. Is that possible that the absence of noise makes the equipment and/or speakers perform better because the noise is not interfering with the actual music signal?
2. If so, are there any real world tests that explore this? I would imagine such a test would have to be one in a anechoic chamber or an otherwise sound isolated space using a very sensitive microphone. But even if you were to capture that sound, you still have to compare it somehow and make sense of it.
