Qudelix-5K Plus discussion & user impressions
john61ct
A fork from here
to keep that one clean, for the original model
A technical measurements thread can be separate, hopefully @Amir will get one soon!
On this page
It is still listed as using ES9219 with same output power and 2.5mm, the only difference being QCC5181 instead of QCC5124, and a 30 band EQ. Maybe the other specs are just placeholder, would be good if they improved USB performance and switched to proper dedicated 4.4mm balanced.
On this page
It clearly has a 4.4mm balanced output in pics and is listed as such
Qudelix published a spec comparison between the new and old 5K a few months ago: https://www.qudelix.com/pages/forum?p=post/qudelix-roadmap-2026-13846459
There are differences between the two spec., but that one did show the 4.4 mm output instead of 2.5mm. Interestingly, it also listed the same power between 3.5.mm and 4.4mm—possible if they make ‘active ground’ the default mode for 3.5mm SE (as hinted by the dual ES9219 for unbalanced).
At the bottom, they also list the new Qudelix dongle, a USB BT transmitter with PEQ (similar to FiiO AirLink & others).
I don't need another portable DAC/Amp, but...
Summary from Google
Since there is no clip on the Q5K+ nor anywhere to thread a lanyard, i'm going to hold off until decent cases are available. Something like this one for the Q5K would do...
Something like this would work, not removable though but as the clip is steel then I imagine you could stick a small/thin n52 magnet on the rear of the qudelix and then magnetically attach the clip as a nd when needed
or this sort of thinhg
They could work, but you're not going to tempt me!
In the words of Mrs Doyle
"Go on, go on, go on, go on!"………….. "You will, you will, you will!, you will”
The money for the Q5K+ is just resting in my account... for a good long rest... :)
I’ve had £100 sat aside for the 5k+ since it was announced so I’ll probably order one tonight despite already owning two 5k’s, I lost my original 5k two years ago so bought another.
Within a week/few hours use of my new 5k I grabbed an old fleece lined hoodie I hadn’t worn for ages to head out with and found my original 5k clipped to the pocket :facepalm:
So I may sell the newer 5k as it’s had less than 5hrs use and still have all original packaging
