In case anyone is interested, I measured the 5K's PEQ filter response as well as its dynamic range in Bluetooth (LDAC) mode and posted here (to compare the FiiO BTR15 with it).
The 5K is exceptional!
EDIT. Actually, I think the test deserves a spot in this thread, too.
PEQ responses in Bluetooth (LDAC) mode were tested between Qudelix 5K pitted against FiiO BTR15:
Measured the dynamic range of both devices' LDAC modes:
It seems that the BTR15's Bluetooth LDAC mode has some kind of clocking/jitter issue, making its FFT unstable---the skirt around the test tone is fluctuating over rolling averages.
The Qudelix 5K's Bluetooth performance (and its PEQ accuracy) is exemplary, explaining why it has been regarded as the best of its kind for quite a while.
There is certainly a problem with the BTR15's LDAC performance, not achieving the sample rate of 96 kHz.Note. The Bluetooth (LDAC) playback of test signals was from the USB Audio Player Pro (UAPP) installed on Google Pixel 8.
