Qudelix-5K Bluetooth DAC & Headphone Amp
How does its app compare to Viper4Android and Jamesdsp?
Difficult to compare as they serve different purpose: the Qudelix app’s (Android, iOS, Chrome ext.) are all about controlling & fine tuning Qudelix devices—the 5K… and T71 (Cr Ext. only).
V4A, JDSP do none of that.
They overlap in the DSP area, but then it’s more about the pros & cons of HW vs. SW DSP capabilities, not really the app themselves.
FW V3.0.0 available through iOS (does not appear to be available through the Chrome extension or Android yet ???) EDIT and Android, and Chrome extension.
The DSP section has been revamped, and now offers two options:
  • "USR/SPK" / "20 BAND"
  • "GEQ" / "PEQ"
This gives 4 possible configurations:
1 - 20 BAND + PEQ - This is the same as before. You get a 20-band PEQ, with a choice of LPF, HPF, PEAK, LSHELF, HSHELF filters (or BYPASS), with adjustable FREQ (10 to 22,000 Hz), GAIN (-50 to +50 dB), and Q (0.01 to 7 EDIT: 0.01 to 15) values for each filter. You also get global HEADROOM (0, -6, or -12 dB), PRE-GAIN (-24 to +24 dB), and XFEED (0 to 50) adjustments. I assume the XFEED is the same proprietary Qudelix Xfeed as before. If you select an AUTO EQ preset, it appears to only use the first 10 filters, filters 11 to 20 are in BYPASS (which you can change and adjust to whatever you like in addition to the preset!).
2 - 20 BAND + GEQ - Same as above, but with +/- 12dB GEQ filters. Global HEADROOM, PRE-GAIN, and XFEED are also available. If you select and AUTO EQ preset, it reverts to PEQ configuration 1 (support for AUTO EQ has only been implemented with 10-band PEQ apparently).
3 - USR/SPK + PEQ - This one is inspired from the T71. You get two sets of 10-band PEQ. The "Speaker" SPK EQ is intended for adjustments to the headphones/IEM frequency response. The "User" USR EQ is left for your personal preferences, depending on what you're listening... If you select an AUTO EQ preset, it is applied to SPK PEQ, and does not affect your USR PEQ, which seems logical.
  • The SPK PEQ gives you a choice of LPF, HPF, PEAK, LSHELF, HSHELF filters (or BYPASS) with adjustable FREQ, GAIN, and Q and a global HEADROOM and PRE-GAIN (no XFEED). In addition, It can be applied to L-only, R-only, or BOTH L & R, but you no longer have the option of a10-band Left PEQ + a 10-band Right PEQ. (EDIT: Actually, you can apply a set of SPK PEQ to L and a separate set of SPK PEQ to R. If you apply a set of SPK PEQ to BOTH, it overwrites the L & R entries and makes them identical... Neat !!!).
  • The USR PEQ gives you a choice of LPF, HPF, PEAK, LSHELF, HSHELF filters (or BYPASS) with adjustable FREQ, GAIN, and Q and a global HEADROOM, PRE-GAIN and XFEED.
4 - USR/SPK + GEQ - This is a mixed configuration of a 10-band (graphical) USR GEQ, and a 10-band (parametric) SPK PEQ. If you select an AUTO EQ preset, it is applied to SPK PEQ and does not affect your USR GEQ--again logical.
  • The SPK PEQ is the same as configuration #3.
  • The USR GEQ is the same as configuration #2, except for 10 bands instead of 20.
This is a quite complex configuration and although it makes perfect sense to me, I suspect it's going to generate quite a bit of confusion and discussions (see T71-related forums...).
On my iPhone, entering values for a given filter seems bogus: the numerical keyboard keeps auto-hiding right after it appears... The work around for me was to select PRE GAIN first for example, and work my way down into each filter: definitely needs to be fixed !!!
Other than that, I spotted two new "VOLUME UP LONG KEY LOCK : RU (long)" and "VOLUME DN LONG KEY LOCK : RL (long)" settings.
The Chrome extension does not reflect this new FW options. I am not sure if it is totally compatible at this very point in time (EDIT: it is not, for example, adjusting PEQ no longer works), but I assume an update is going to follow very soon.
EDIT 2 - With the QX-Over IEM (not sure anybody cares about that IEM…), “USR/SPK” is the only option with V3 fw. It is greyed out and “20 BAND” cannot be selected. “GEQ” / “PEQ” does not appear anymore.
So you get a 10-band “Speaker” PEQ, and the “USR EQ” tab is replaced by “QX-OVER”, where you find the same controls as before: LOW GAIN (-6 to 0 dB, default is 0. Low as low Freq.), HIGH GAIN (0 to +6 dB, default is +6. High as high Freq.), LOW L/R TRIM and HIGH L/R TRIM (-3 to +3 dB for each, default is 0). I suppose the bank of filters used for “USR” is now dedicated to “QX-OVER”, implementing LPF and HPF instead.
I’m waiting for the T71 IEM, with its 4 active drivers (vs. 2 in the QX-Over), to see if Qudelix implements similar controls or they do something different.
EDIT 3 - The Android Qudelix app has been updated and FW V3.0.0 is now available through Android.
EDIT 4 - The Chrome extension has been updated as well. The USR/SPK, 20 BAND, GEQ/PEQ options are arranged slightly differently as compared to the Android/iOS app: there is only a "USR/SPK" / "20 BAND" choice in the OPTION screen, the "GEQ//PEQ" choice is a pull-down menu in the "USR EQ" screen. But overall, the Chrome extension and the app provide access to the same features.
Screenshots from the Chrome extension DSP section:
DSP OPTION
DSP USR EQ - GEQ
DSP USR EQ - PEQ
DSP SPK EQ
DSP SPK EQ - Separate L & R PEQ
DSP AUTO EQ PRESET
I also noted that Qudelix "ACTIVE GROUND" option is back (?? maybe it was already available in previous version... I lost track ??).
This is the same as the T71: it ties the L- and R- together to a zero, virtual ground level. This provides more current capability to the 3.5mm 2.5mm output (e.g. for low-impedance HP, as the 4 amp / 2 chips are used, vs. 2 amp / 1chip in the normal SE mode), and the ghost/virtual ground can help eliminate ground loop issues.
"Ghost Ground" was the original name used by Qudelix. Here is their original diagram:
Note that you need a 2.5mm to 3.5mm (or any other SE output such as RCAs) to use that feature.
EDIT 5 - iOS V3.0.1 & Android V3.0.01 are available (Chrome extension update pending?). Not sure about the fixes. I noticed that max Q is now 15. From what I read elsewhere, this was already the max value for the Chrome Extension. On my iPhone, I still have this jarring hit & miss keyboard entry for any PEQ value--not sure what's going on...
FW V3.0.0 available through iOS (does not appear to be available through the Chrome extension or Android yet ???).
  • "USR/SPK" / "20-BAND"
  • "GEQ" / "PEQ"
1 - 20-BAND + PEQ - This is the same as before. You get a 20-band PEQ, with a choice of LPF, HPF, PEAK, LSHELF, HSHELF filters (or BYPASS), with adjustable FREQ (10 to 22,000 Hz), GAIN (-50 to +50 dB), and Q (0.01 to 7) values for each filter. You also get global HEADROOM (0, -6, or -12 dB), PRE-GAIN (-24 to +24 dB), and XFEED (0 to 50) adjustments. I assume the XFEED is the same proprietary Qudelix Xfeed as before. If you select an AUTO EQ preset, it appears to only use the first 10 filters, filters 11 to 20 are in BYPASS (which you can change and adjust to whatever you like in addition to the preset!).
2 - "20-BAND" + GEQ - Same as above, but with +/- 12dB GEQ filters. Global HEADROOM, PRE-GAIN, and XFEED are also available. If you select and AUTO EQ preset, it reverts to PEQ configuration 1 (support for AUTO EQ has only been implemented with 10-band PEQ apparently).
3 - USR/SPK + PEQ - This one is inspired from the T71. You get two sets of 10-band PEQ. The "Speaker" SPK EQ is intended for adjustment to the headphones/IEM frequency response. The "User" USR EQ is left for your personal preferences, depending on what you're listening... If you select an AUTO EQ preset, it is applied to SPK PEQ, and does not affect your USR PEQ, which seems logical.
  • The SPK PEQ gives you a choice of LPF, HPF, PEAK, LSHELF, HSHELF filters (or BYPASS) with adjustable FREQ, GAIN, and Q and a global HEADROOM and PRE-GAIN (no XFEED). In addition, It can be applied to L-only, R-only, or BOTH L & R, but you no longer have the option of 10-band Left PEQ + a 10-band Right PEQ.
The Chrome extension does not reflect this new FW options. I am not sure if it is totally compatible at this very point in time (EDIT: it is not, for example, adjusting PEQ no longer works), but I assume an update is going to follow very soon,
I also updated to V3.0 on my iPhone 15 today. As expected, my EQ settings were not saved. I tried to add my saved .txt files of the settigns in the Chrome add-in and they would not not properly load. Also, I manually input an EQ profile on my iPhone/5K app and it did not show up when I opened the chroime extension. Looks like we need an update to the Chrome extension. Currently at 2.3.2.12.
I have updated to v3.0 Android app, Chrome add-in and the firmware on my Q5K (via Chrome add-in). I lost all my PEQ filters, which was expected. I like the new separation between PEQ for correction and for preference. I have noticed a couple of other things...
1. Enabling XFeed on the User EQ applies crossfeed. Disabling User EQ does not disable XFeed (you have to re-enable User EQ and zero XFeed for it to be turned off).
2. The Q5K now says 'Power Off' when shutting down. I think it played a tone before and that tone was quite similar to the power on tone - making it difficult to determine if I'd powered the device on or off! (IIRC - this is a reversion to the experience with the Radsone ES100)
They should still be there, but only if you select the 20-band mode.
Yes, they are, thanks. They were all pulled from AutoEQ, so it's no bother to re-download into the SPK PEQ list. I will have to re-enter impedance and sensitivity for each setting as this is not pulled from AutoEQ and has been lost from the settings preserved for 20 band PEQ.
I also like that option... The new FW V3.0 allows for some interesting use case scenarios:
20 BAND mode
20-band GEQ - Use when you want to "visually" adjust a HP/IEM FR.
20-band PEQ - Use when you want a (almost) full-fledged 20-band hardware-based PEQ to tinker and fine-tune a headphone or IEM.
20-band PEQ with active ground - Use when you want to use the 5K as a DSP-enabled single-end preamp :cool:. I don't know whether this "active ground" feature improves SINAD and else... :p
USR / SPK mode
I find this mode particularly interesting when combined with the AutoEQ presets. Let say I want to compare IEM-A with IEM-B.
First, I load the AutoEQ preset for IEM-A from, for example, Oratory1990 measurements. They are loaded in the SPK PEQ section. First question, here: I haven't figured out what target and (?) AutoEQ advanced settings, Qudelix is using to upload the 10 PEQ filters from @jaakkopasanen AutoEQ into the SPK PEQ. But let say, it mostly works for me, except for too much bass... I correct this by adding a -3db low-shelf filter in the USR PEQ. I also like to push the high a little, per Knowles white paper. This becomes my personal preferences in USR PEQ, on top of the AutoEQ in SPK PEQ.
I then switch to IEM-B, load the corresponding Oratory1990 AutoEQ preset, my low-shelf filter and high PK filters in USR PEQ are still here, unchanged. If Oratory measurements and AutOEQ are done properly, IEM A and B should be very close to the same target... and they both play with my added USR PEQ personal preferences. So, now, I can focus on IEM A & B differences. If I "hear" a difference :rolleyes:, I can peek into the SPK (AutoEQ) presets and tweak ssome of the filters, or I can play with and add some high-Q filters in the USR PEQ section to find whether the difference truly exists and where it's coming from: is it this distortion peaks in IEM-B? Do get a tad more sibilance with IEM A? Is there a minute FR difference in one area I'm very sensitive to?
This makes for a very nice user experience.
One detail I would like to see in a future update: There is an option to have separate L & R SPK PEQ filters. This is great if your Headphone / IEM (or room in preamp mode?) lacks consistency between L and R. But as a user, how would I know this without some fairly advanced measurement? What I do know however, is that my let and right ears are not the same... I would love to see Qudelix adding the same L/R/BOTH option in the USR PEQ to allow for differentiated L/R personal preference.
I was able to "move" all my old 20 band PEQ settings to the 10 band simply by downloading and then re-uploading the TXT files via the app, the app automatically selects the first 10 PEQ values to apply into the 10 band mode.
Luckily I don't have any PEQ that were using more than 10 bands.
Thought of another killer use for the Qudelix: to use my IEMs with my Denon AVR with the same EQ profile as every other source. This would be great for times when I need to be quiet. The AVR is right behind my seat as I prefer putting the equipment rack at the back of the room to clean up the front and leave more room for speaker placement. But even if it weren't, Bluetooth would make this possible still. I just need a Bluetooth transmitter that can do LDAC. Any ideas?
Interesting...so my next line of thinking is whether you can even connect one of these to an AVR (Denon X4500H) as an output. That idea may be dead in the water. It may have to connect to the TV which means only TV apps will output to it and a game console or 4K UHD player that's connected to the AVR will not.
The BTA30 Pro has an SPDIF-in, so if your AVR has one output, it should work. If not, you may have to look at an “HDMI extractor” to get SPDIF digital out…. but you start to pile black boxes on top of black boxes! :)
My attempts to pair my Qudelix 5K to my Sony A80K have so far been unsuccessful. The display simply doesn't see the device.
Edit: in the Qudelix app I selected under Bluetooth Mode for USB DAC: "Disconnect A2DP". It's not intuitive, but it works. Now I'm watching YouTube with my equalized IEMs and that's most of my use case. I'll have to figure out gaming and movies later.
I love this change. 20 bands IMO was more for tweaker-neurosis than listening to music. If a headphone can't be made good to sound good with <10 bands of PEQ it's probably better to just scrap it and use a better headphone.
Also, a user who gets EQ curves from Amir or Oratory or autoeq.app or wherever but has learned she has a slightly different preference (say, more/less bass) can keep the original data pristine and overlay a preference set. Or, create presets for common listening levels to compensate for the lack of loudness compensation - the only relevant and material audio feature missing from Q5k IMO. It's also neat that crossfeed is included, so you can use the "USER" panel to just have several levels of xfeed.
The only real confusing thing is the names. I would've gone with something like "REF" and "PREF" for, respectively, the original data/listening based EQ and the user preference overlay. "SPK" for headphones is not technically wrong, but it sounds weird.
This is the same as the T71: it ties the L- and R- together to a zero, virtual ground level. This provides more current capability to the 3.5mm output (e.g. for low-impedance HP, as the 4 amp / 2 chips are used, vs. 2 amp / 1chip in the normal SE mode), and the ghost/virtual ground can help eliminate ground loop issues.
So basically this is an amp channel bridging mode? What kind of adapter is needed to use it? This could be very useful for people with headphones that have stupid expensive aftermarket cables due to proprietary connectors. They can use their normal cable and get more power. I'd be interested to hear this with DCA Aeon 2 Noire, for example - Q5k can drive them "loud" from the 3.5mm jack but with noticeably squashed dynamics compared to an RME ADI-2 Pro SE. I've recently been comparing two closed headphones, Aeon 2 Noire and Austrian Audio HI-X60; the latter sounds basically the same using the same EQ settings on RME and Q5K at any volume with no loudness engaged on RME, but A2N sounds more compressed on Q5kI suspect that the bridged/balanced mode will offer an improvement there.
Happy to say I've solved my audio issues with my Pixel 8 with the Qudelix 5K.
No surprise that going from general purpose computer to dedicated audio hardware is a smart move.
It's either that or my OWC Thunderbolt 4/USB hub responsible for the low noise. I get a ton of noise connecting DACs directly to the PC which had me switching to optical out with desktop DACs.
Unlike the general computing market it seems, Mac users have standards. It follows that companies catering to the Mac market such as OWC don't survive unless they meet Mac user standards. :)
I have no idea what kinds of horrific noises one would get plugging an audio device into a work laptop (in my field they tend to be very tightly locked down to protect) but there is none into my M1 MBP either.
No adapter. It uses the 4 internal amps of the 5K but, in that case, the 2.5mm bal. output is not used. Instead, 2 of the internal amps are routed to the L+ and R+ of the 3.5mm single-end output, and the two others amps are tied together to the “ground” of the 3.5mm SE, but with a “0” level—a “floating” ground.
So, it is to use with a standard 3.5mm SE cable.
Are you sure? "Active Ground" is greyed out when I plug in a headphone to the 3.5mm jack. I haven't tried with a 2.5mm TRRS cable.
FWIW, since it looks like Qudelix is taking an active interest in improving the 5K even more, I just sent them the following feature request (along with a request to change the labels for "USR" and "SPK" to, respectively, "PREF" or "PRF" and "CAL" or REF"). Maybe if more people do the same it will be something they consider looking into:
"Would you consider a feature request: loudness compensation with a level offset? Look at RME for an example of a superbly executed DSP loudness "circuit," or the Monoprice Monolith HTP-1. Loudness could be part of the user-adjustable panel as well. What would be super cool is if you added it as a kind of “Auto EQ,” where the curve in the current "USR" “USR” pane would show your overlay to the calibration curve loaded in the current “SPK” pane PLUS the volume-dependent EQ applied by the loudness function at the current volume level and volume offset setting."
Oh yeah, you’re correct! My bad! I checked the Qudelix forum, and yes, it only works with the 2.5mm bal. output. I also checked with a 2.5 TRRS cable and yes, the Active Ground option is enabled.
So you need a 2.5mm male to 3.5mm (or anything else that is single end L/R) adapter.
I have a 2.5/3.5 adapter for my E1DA PowerDAC. It should work with the 5K Active Ground mode…
I would also like to see a differentiated L/R “USR” option like they have in the “SPK” tab: my L & R ears are not the same, and although my brain can “process” the difference, I like being able to fiddle with separate L/R EQ.
On the technical side, I’m pretty sure these DSP banks are separated anyway, so it should be a SW-only change…
To follow up: I am able to get my other devices working with my Q5K by setting my AVR to "passthrough" the appropriate HDMI channel (yes it does mean I have to go in and switch this). Then when the AVR stays turned off, my BDP or PS4 essentially have a direct connection to the TV. I could pair the Q5K directly with the source devices but that was more connections than I wanted to manage. And, I wasn't sure if I would run into any audio sync issues if the audio and video were being handled by two different devices. Everything going through the TV is simpler in my view and I let it handle the A/V sync.
So my uses for the Q5K now include:
Android Phone w/LDAC
Windows PC w/USB
And when I need to be quiet and keep the HT system off, but want to play a game or movie:
Sony A80K w/A2DP, AVR set to HDMI passthrough
...my IEMs sounding the same from every source because the Qudelix is handling the EQ profile. Perfect!
The only thing I have left to test is sending PCM vs "compressed audio" from the Sony OLED. Basically, I am unsure if the Q5K will do a stereo downmix or if I need to have the TV do it.
