I have one of these units and decided to do some tests to see if I could improve the measurements out of it by changing out the power supply. In order to test this I got a $20 dollar Anker battery bank for a phone, a topping HS02 USB isolator, and a iFi SilentPower iPower X Black. I did self tests with the Q403 on only the left channel in balanced with the right channel capped off with 50ohm BNC caps. The left channel went BNC to RCA adapters and then the cables used were two Blue Jean Cable LC-2 cables.
The topping HS02 was used because it is a USB isolator and doubles as a USB power injector, allowing me to use the extra power supplies.
Measurements were taken with a 20 to 20k bandwidth, and with a 20 to 96k bandwidth. Initially I had issues with a bunch of 60hz and 60hz harmonics leaking into my measurement but this was rectified by moving the QA403 off of directly on top of my Tripp-Lite power conditioner to as far away from my computer as possible and turning the lights off for good measure.
Lets start with the 20 to 20k tests.
Here is the QA403 running a simple self test while connected directly to my computer.
Here it is connected to the Topping HS02 with the cable that came with the HS02. A very slight improvement. barely even noticeable, definitely not worth One Hundred American Big Boys.
Here is the $20 dollar Anker Battery bank. Another very slight improvement.
And finally the iFi SilentPower iPower X Black. This device costs $120 dollars on Amazon, and
claims a noise floor of around 1uV of noise. It outputs 5V at 3A. For context on the noise floor a
Keysight benchtop power supply that costs over 11 thousand dollars gets a noise floor of only 10uV. What a deal!
Unfortunately the claims are just claims and it fails to perform better than the battery bank, and worsens the performance compared to no adapters at all.
Maybe the iFi can redeem itself with the wide bandwidth tests.
Once again here is just the QA403 plugged directly into the computer:
Here is just the HS02 wide bandwidth. Slightly worse across the board.
Here is the Anker Battery bank, once again even worse than the the HS02.
And here is the iFi SilentPower iPower X Black in its final attempt to justify its own pricetag:
And although that is better than the battery, or just the HS02 by itself that is not better than just plugging the QA403 directly into your computer.
It looks like Quant Asylum did an excellent job on the power supply, and any gains that can be made with external components are either minimal or non-existent.
At the very least it was a good bit of fun for an afternoon.
