Quant Asylum QA403 Audio Analyzer Review
Rate this audio analyzer:
    Votes: 1 0.7%
    Votes: 2 1.5%
    Votes: 35 25.7%
    Votes: 98 72.1%
Does not work if there is a latency and clock mismatch between DAC and ADC. Amir’s comment on window effect on amplitude and rms was valid for older SW analyzers. The SW like REF automatically corrects for window transfer function, by maths.
Getting into the weeds, I think latency should not matter, but a clock frequency mismatch is killer without windowing, yes? At least testing I have done, and the standards I reference, ignore latency except in special cases where it must be compensated for time domain signals (e.g. radar, lidar, sonar, etc.) A clock mismatch is a killer without compensating and/or windowing. For a test box like this, I'd guess there is a master clock driving the DAC signal generator and ADC to capture the signal, so should be synched. If the generator were analog, all bets are off.
Except for purists and reference-level testing, this looks like a killer device for a hobbyist or bench tech doing analysis for "fun". I want one, but can't really justify it.
Are speakers more difficult to test or are they more difficult to come by?
Both. I do have a decent backlog of them though. Getting them measured is half the battle. The other is listening, creating EQ, performing AB testing, etc. I have for exampled measured a speaker two months ago yet haven't had time for the second half of the work.
There are a lot of reviews here of boxes that I don't even understand what they do. Not really interesting or helpful for the vast majority of the people.
Many read them because they are educational as far as learning about audio even if they don't interest you as a product. It is the old adage of "teaching you a fish" instead of handing you one.
I also have a life to live and that life tends to get complicated quickly during good weather summer season.
Speaking of amplifiers, do they propose a LPF to measure class D amplifiers ?
I purchased my QA403 a year ago and no LPF was offered at that time. I built my own based on a DIY design posted by Clockworks.
@DonH56 Maybe I was not specific enough, what I mean is a non-constant clock difference (DAC x ADC) and filter delays. Sometimes it makes measurements impossible.
Ah, 100% agree. I misunderstood your latency reference, sorry, I was thinking of a fixed (static) latency.
Reactions: pma
It was my fault not to be specific enough.
Hmmm ....
Below from the analog shown above. 1 x Hann 32k, 1x Blackmann-Harris 32k, 1 x 256k Blackmann-Harris
I thought that maybe I had outdated version of REW, but I updated to the latest beta and here's what I get around 951.4 Hz (for 48k sampling rate and 32K FFT size, that frequency is on the border of two bins):
But the numerical value of the level in the RTA panels was calculated correctly.
If REW is the generator, we can also "Lock Frequency to RTA", in case of doubts. But I never doubted REW.
So do you lock the frequency or not? That's a bit unclear to me :)
The additional advantage of carefully choosing the frequency (or locking, in REW terms) is getting rid of the "skirt" at the bottom, especially if the only available window is Hann:
That's is what I did. As I note though, your response time reduces sharply as you to now wait for that much data to collect. 96K points for example will take more than 2 seconds to collect at 44.1 kHz sampling.
That's something different then. Both FFTs in my example were from 32'768 samples of actual data. For the 128K FFT the data was zero-padded, so there is no need to wait longer.
How about different window? However, you are saying that calculated values are correct. So is it any issue?
Who or what did the padding? If it is a manual process, then it doesn't count as you can't do that for real-time measurements.
They seem ok.
No, not an issue to me. I was only reporting a funny/weird thing I noticed.
In that example, my tool ( https://codeberg.org/danadam/spectrum ).
When I said "One could use oversampled FFT (although I don't know if anyone does)", I only meant it is a method that a measurement software could implement, in which case that software would have to do the padding.
There is nothing flimsy about C. It is used in the most demanding real world application - smartphones - which are plugged and unplugged every day and often used whilst plugged in.
Why on earth would something like this need another type of connector? It makes zero sense!
And I have to replace USB-C cords I use with iphones regularly because they fail. I have had to change the port I use for the docking station of my employer's Dell laptop because the port I was using for a little over a year (with daily plugging in and unplugging) became intermittent.
And that doesn't include the issue with the cables losing their ability to seat tightly and stay connected.
I never had any of these problems with the various USB-3 plugs and sockets used prior to the EU requiring the USB-C plug.
USB-C has the advantage of being compact and reversible, but it's not as reliable for equipment used for more than a year or two as is often claimed.
Rick "gets about six months out of a USB-C cable, even the expensive Apple-branded ones" Denney
If this is your legal name then let me say right now that you might be the coolest MF on the planet. Even cooler than Rick James.
It is my legal name but I have no idea why it is cool :)
On the topic: I bought a QA403 about six months ago, but life has intervened (hence my reduced ASR participation) and I haven't even pulled it out of the box yet. I did move a computer up to my electronics bench--something I had been putting off because it's a vintage bench with vintage test equipment--but I haven't spent the several days it will take to get everything integrated. I'm hoping the QA software will run on Windows 10, because I do not want to buy a computer just for this.
My HP 8903 analyzer can measure performance up to about 100 dB, which in my view is good enough for vintage equipment and also good enough for what any of us are likely to be able to hear without extraordinary techniques. But making full-spectrum measurements with it is laborious because it lacks automation. There is software that will automate an 8903 and I have that software plus the GBIB cables and adapters needed, but that's even more integration work than setting up the QA-403.
This will be a fun winter weekend project.
Rick "in no hurry" Denney
For the graph I shared in my previous reply, yes.
But I never use it, mainly because for the devices I like the most to review (CD Players), I can't use it since REW is not the generator. The other reason is that I like to test the pitch-error of the player, and for that I go much higher FFT resolution, that's all.
For the purpose of checking the output voltage of a device, which I understand was the starting point of the discussion, I use the standard BlackMan-Harris7 window of REW, keeping the FFT length close to the SR of the ADC (32k for 48kHz, 64k for 96kHz, 128k for 192kHz, ...). It's good enough, increasing the length does not change the reading. Also, these graphs visually align with those of Amir, so they are consistent when it comes to visual level of noise floor which is influenced by the FFT Length (and averages too).
How many USB-B docking stations have you used? In my experience that connection is seldom used for things which are plugged in and out as often as USB-C.
