Quant Asylum QA403 Audio Analyzer Review
Rate this audio analyzer:
    Votes: 1 0.7%
    Votes: 2 1.5%
    Votes: 35 25.7%
    Votes: 98 72.1%
Note how the reported level of 1.914 Volt RMS is wrong. The fed input was 2 volts, not 1.91. The error (9.6%) is introduced due to the Hann window function which impacts the accuracy of spikes in FFT where the number is computed. You can select flat top to solve that but then get massive spectrum leakage and elevated noise floor in FFT. You can then counter that with very large FFT and averaging. Once there, you have better accuracy but very slow response.
One could use oversampled FFT (although I don't know if anyone does):
-0.6 dB from 2 is 1.87, if anyone's interested.
It’s also more secure, less prone to be yanked out than a USB-C cable/connector. As an example, E1DA is selling a special USB-C cable with an integrated locking screw to use with their latest Cosmos ADCs…
But only for the data port, for some reason (i.e. only the data port has the screw hole).
And the locking mechanism for USB-C is actually standarized.
Are speakers more difficult to test or are they more difficult to come by? That's why I love Erin's Corner, it's mostly speakers. Amps are important, too, but they pretty much sound the same, maybe the power and noise is important to measure, but speakers make most of the difference. There are a lot of reviews here of boxes that I don't even understand what they do. Not really interesting or helpful for the vast majority of the people. Not to say this forum isn't a goldmine, I've bought speakers reviewed here and relied on the measurements, I was never disappointed, the data always matched with what I heard, but lastly there are too many strange boxes, tons of dacs that are all the same. The last two, at least, are 2 useless devices. The previous one disproves a myth, so it's important in that respect, but otherwise, almost nobody will buy these boxes that do god knows what...
Very poor implementations, then. Like 40 years ago. Well designed SW like REW makes the calculations properly, regardless the window used, regardless the FFT length.
Now Hann, 32k and 256k
No problems, just run-to-run deviations.
Even 8k flat-top holds strong.
Sure, when there's the possibility to adjusts the frequency of the signal. You got there:
  • 1001.96 Hz at 16K,
  • 999.03 at 32K,
  • 1000.13 at 256K
The situation I had in mind, was when you can't change it, e.g., if you get exactly 1 kHz from an external source.
Reactions: pma
I will try.
The freq. related to FFT is done automatically by REW - if you check the checkbox.
Still no other difference than analog generator level fluctuation. The SW has to be sophisticated enough to cover window transfer function. And the REW is.
To catch the peak value - oversampling + interpolation.
Yes, it is, although it seems to be doing funny things with the plot, when you zoom in:
Here 996.09 is in the middle of the bin, 999.02 is right between bins and 1000.0 is just... round value.
Hmmm ....
Below from the analog shown above. 1 x Hann 32k, 1x Blackmann-Harris 32k, 1 x 256k Blackmann-Harris
Fine example of entitlement.
Maybe I am getting old but this type of response really irritates me. If you don't understand something it is better to remain silent.
Best for you not to read such reviews that you do not understand what are good for.
I agree.
Please only test the products I understand and know how to use
wut.
If you mostly want speaker test results, go to websites that specialise in that.
If you want a specific device tested, talk to testers maybe sponsor it being sent over.
I think you don't know how to use the website?
Or your definition of average is extreme.
It is true that average users are very different from objectivist audiophiles.
I only get the most recent reviews from the dedicated index pages (is Android limited?)
Google suggests these search strings:
• For Electronics (DACs, Amps, Streamers):
site:audiosciencereview.com "review and measurements of" amirm
• For Speakers:
site:audiosciencereview.com "speaker review and measurements"
• For Headphones / IEMs:
site:audiosciencereview.com "headphone review" amirm
• To find high-performing electronics using performance metrics:
site:audiosciencereview.com "review and measurements" SINAD
If you are looking for a specific brand or model, just append it to the end of the query (e.g., site:audiosciencereview.com "review and measurements of" Topping D90).
If I am serious? What do you Think? Amirs work is second to none but unfortunately he dont get hifi devices on the bench that the average hi fi consumer are using or considering.
Point taken. But why ranting? No suggestion of yours can be found in the threads suggesting what Amir should test next. That could be more positive way to deal with what you complain about.
If REW is the generator, we can also "Lock Frequency to RTA", in case of doubts. But I never doubted REW.
Does not work if there is a latency and clock mismatch between DAC and ADC. Amir’s comment on window effect on amplitude and rms was valid for older SW analyzers. The SW like REF automatically corrects for window transfer function, by maths.
Compensating the level for windowing is a fairly simple calculation run after the FFT. You can't really compensate for the spectral leakage without corrupting the results, but fixing the absolute level is a simple multiplier easily applied. Not sure why Quant Asylum isn't already doing that, maybe they just didn't think about it, and/or assumed the error in absolute level was small enough to not matter to most folk? It also creates error in the displayed absolute noise floor of the FFT, again small enough to be ignored by most, but vexing when compared to a more rigorous test system. To me, the biggest potential issue for testing is with a device like a DAC that has little to no headroom beyond full scale, so nudging the level up a little may increase distortion more than expected. It is pretty common to test at -1 dBFS, for example, to limit the chance for noise peaks, inter sample overs, and such, so using the Quant Asylum unit eliminates that margin. Again, I do not consider it a big deal, just a tweak that really should not be needed.
Reactions: pma
That's is what I did. As I note though, your response time reduces sharply as you to now wait for that much data to collect. 96K points for example will take more than 2 seconds to collect at 44.1 kHz sampling. And if you are averaging, it will seem like an infinity waiting for things to settle.
