Hi, I've been a member here only for a short time so feel free to give me any feedback if this post is inappropriate or in the wrong forum.
I'm trying to find out the output topology of my QSC Touchmix 30 mixer.
So I'm guessing the two most likely topologies are those described in the diagram above. (Please ignore the value of the 1k resistors - I realised afterwards they're unlikely to be so high.) The top one is a pair of op-amps, one driving the positive, the other the negative. The bottom one is a single op-amp driving the positive, and pin 3 tied to ground via a resistor that makes the output impedance on pin 3 match that on pin 1.
Which topology is used matters a little to me. I want to connect (for training purposes only) a speaker with an unbalanced input. If the output uses two op amps, bridging pins 1 & 3 on the XLR plug means the op-amp driving pin 3 will have to work very hard, leading to heat and potentially damage.
(It's possible, by the way, that the mixer's Aux outputs have a different topology to the Main L/R outputs, as I heard somewhere that while there's two electrolytic capacitors for each of the main outputs, there's only one for each of the auxes.)
